Windows 7: Swap left/right audio channels
27 Mar 2011   #1
SoWhy
Win7 Pro x64 / WinXP x32
Hi there,
due to the layout of my new desk, I have to keep the speaker which outputs the left stereo channel on the right and the one that outputs the right channel on the left. As such, my sound is now inverted, which is especially annoying when playing games.
Does anyone know if there is a on-board solution or a tool to swap the audio channels?
TIA
SoWhy
PS: I tried to search for a solution first but most where like "just swap the speakers" which I cannot do due to insufficient cable lengths
27 Mar 2011   #2
mrdemon
Windows 7 Home Pre
Other than Buying a 3.5mm Jack headphone extender as far as i know it cant be done, But saying that in a Old game (UT2k4) in the settings and audio area there is a reverse stereo. So have a look at your games setting menu you never know it might be there.
Regs
27 Mar 2011   #3
CovertDeath
this is the closest thing i could find for you software wise if you don't have a utility to do it... its a free to try thing but you might have to pay later... i think a better option would be extension cables but this is technically what you are asking for...
Swap Speakers Software for Windows 7 - Swap speaker output. - Windows 7 Download
though im not really sure what EXACTLY it does, it could just be pin re-assignment too lol
17 Jun 2016   #4
EdRoxter
Windows 7 Pro 64Bit
I know, this is an old post, but since it pops up as the first result in Google when searching for "Windows Swap Audio Channels", I thought it would be good posting a working solution here:
  • Download Equalizer APO from https://sourceforge.net/projects/equalizerapo/
  • Configure it to attach to your output device (Usually something like: "Speakers - VIA HD Audio" or "Speakers - Realtek HD Audio"); you can change this later with the "Configurator" tool from the Equalizer APO start menu folder
  • Create a new file in C:\Program Files\EqualizerAPO\config, name it for example swapchannels.txt
  • Paste the following line into it as its only content:
    Copy: L=R R=L
  • Save it
  • Open Equalizer APO's configuration editor
  • Make sure that your device is the correct one in the dropdown menu on the top right
  • If applicable, remove all pre-configured options by clicking the red "minus" icon (or, if shown, the button with two arrows pointing downwards, then "Remove")
  • Click the green "plus" icon to add a new configuration for your output device, then navigate to the "Include configuration file" option
  • Select your swapchannels.txt file
  • Save/Apply the configuration
  • Voilą!
tl;dr:
Install and configure EqualizerAPO for your output device with only one configuration file that has only
Copy: L=R R=L
as its content.
Hope this helps!
07 Oct 2016   #5
EmpCharles
windows 10 64 bit
nope
It doesn't work, in fact the configuration editor tool will just crash if you try and do that, then becomes in-openable because it crashes instantly when you try and do so.
I'd really like to fix this tho
31 Oct 2016   #6
Reyand
Windows 7 x64
Quote   Quote: Originally Posted by EdRoxter View Post
  • Download Equalizer APO from Equalizer APO download | SourceForge.net
    Copy: L=R R=L
  • Save it
  • Voilą!
tl;dr:
Copy: L=R R=L
as its content.
Hope this helps!
Works perfect for me, thx a lot !
Just want to add, you need to restart your PC after installation.
No 2.1 audio channels
Hello I just bought a 2.1 Logitech speakers. The problem is, there is no bass going to the subwoofer, and also there is no option to select 2.1 audio channel. Other info. Subwoofer is connected to AC If I connect my phone and play a sound, the subwoofer works. Realtek HD audio manager is up...
Win 7 Media Center - TV - No audio on HD channels
Hi, I wonder if you can help. I have recently purchased a PCTV Nanostick DVD-T2 290e I am running Windows 7 Home Premium 64bit and I use Windows Media Center for almost everything. I run a media center machine in my lounge through my Sony AV Amp onto my HD TV. I bought the Nanostick to...
Media Center
How do I get more Audio Channels?
I mean... seriously all it shows for me is "Stereo". http://img1.UploadScreenshot.com/images/main/10/27921202143.jpg I only have 2 Devices available, one is Realtek Hd Audio (the one with only Stereo, but it has Dolby Surround Sound, idk if that replaces the options of choosing 5.1 or better)...
How to decrease audio quality without losing channels.?
Hi to all seven forums. hope all will be fine. guys I extracted an audio from a mkv movie using mkv merge gui, and this is the audio status. . Complete name : The Green Hornet 2011 1080p BRRip.mkv Format : Matroska File size :...
Left and right channels are mixed together
Hello I want extend cable on my CREATIVE HS-800 Fatal1ty Gaming Headset. I used many 3,5mm to 3,5mm M/F extended cables but all times the LEFT and RIGHT channels were mixed together. When I set Only left chanel it play 50% on left and 50% on right...etc. Without extended cable everything is OK....
Switching through audio channels in an MKV file
Hey there guys, me again So I got this 1080p MKV file which is a BDRip of a Movie, but it has two audio channels integrated into it - there's one in German and One in English. Obviously, I'd wanna be watching it in English, but no matter where I play it it plays German as the default language. ...
Music, Pictures & Video
