built in microphone for Latitude E5510 not working
  1. Posts : 2
    Windows 7 Home Premuim 32bit
    I have problem with the built in mic for my brandnew laptop (3 weeks old), so don't think that it is a hardware problem. I tried to reinstalled everything but does not work. I was infected by a spyware, then install AVG and scan the system, but as soon as the spyware was removed, so was my mic.
    Thanks for help.
  2. Posts : 391
    Windows 7 Professional x64 Backtrack 4 R2
    Make sure you have all the required drivers installed for your system, you can get them from here
  3. Posts : 2
    Sadly I tried what you have suggested . What Dell technical support said was I should reinstall the Windows 7. That sucks!
    Let me know if you have other options.
    THanks a lot
