Realtek audio working for 64 bit, but not 32?
Hi. I'm using 64 bit Windows, and I'm having an issue.
Applications that are 64 bit seem to play sounds fine. Browsers, some games, etc. 32 bit applications, on the other hand, don't detect a sound device. Winamp, for example, gives a "bad directsound driver" error.
DxDiag continues the problem. The 32 bit version doesn't detect a sound card, but the 64 bit version shows no problems.
I've tried updating the realtek drivers a few times. Tried cleaning beforehand or letting the installer do it. No dice.
Any bright ideas? I've attached both dxdiag outputs. Thanks.
Motherboard is a GA-P67A-UD4-B3.
