No Audio Devices Installed, Help !~!
Simb
1:46 PM
i recently change my windows from XP to windows 7. my VGA also change to a new one. when i test the sound, i cant hear at all !! i go to the contol panel, and check the sound, its say "No Audio Device Installed". i check again through the device manager, in sound,video it seem High Definition Audio Device (not my audio device) and NVIDIA high definition sound. under the other driver, there a ! icon or Unknown Device.
im using Simbadda CST 5000 audio device
Sorry guys for my bad english
Thx
Sound Card: High Definition Audio Defice
Windows 7 32-bit
Windows 7 32-bit
Hi, welcome to the forums :)
You may want to Uninstall the unknown device. Just right-click in Device Manager then select Uninstall. Reboot your machine then allow Windows to try to connect to Windows Update to search for new drivers.
Windows 7 Ultimate x64AMD Sempron Dual Core3GBNVIDIA GeForce 6150SE nForce 430
Compaq Desktop
3GB
1024x768
150GB Sata
i unninstall the Unknown Device and nothing change. its kept coming out when im rebooting.
Windows 7 32-bit
Windows 7 32-bit
Thx
what motherboard are you using?
Windows 7 Ultimate x64Intel Core i7-2600K16 GB G Skill F3-10666 CL9D-4GBRLATI Radeon HD 6870
Something I threw together
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
ATI Radeon HDMI / Realtek ALC892
2 x 22" standard monitors / LG32LC56v TV to watch films
1920 x1080
2 x OCZ Vertex2 111.79GB
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
1 x Hitachi5K320-160
Thermaltake Toughpower Cable Management 750W
Antec 300
Noctua NH-U12P SE2 and 5 120mm Case fans
Microsoft Comfort Curve Keyboard 2000
Hama M3110 / Logitech M305
I have also used Fedora, Suse, Ubuntu Linux
And all other Windows from 95 to date except ME
hello pooch, can you help me? i have the same problem, i will vary much appreciate it if you cold so by help me, thank you.:thumbsup:
Win7 Ultimate x64bit
