New Sound Blaster 5.1 VX card crackling and low volume...
Synica
8:01 PM
I've had my new sound card for over a week now, and I've had constant problems with the sound since then. It's better than the complete lack of sound I had before, but now it's starting to get on my nerves.
My SB 5.1 VX card constantly makes crackling noises when in windows and other audio is not playing besides regular windows sounds (folder opening, errors, etc) and even with all volume set to maximum, it's still incredibly quiet all the time.
I use a pair of headphones, although the speakers have the same issue when I use them. Neither speakers nor the headphones have drivers or anything of the sort. They're both plug and play.
Any assistance fixing this problem would be appreciated.
Windows 7 Home Ultimate x64.Intel i7 Quad Core (3.5Ghz)Corsair 2x 4gb DDR3NVIDEA Geforce GTX 460
Asus Sabertooth Z77
Corsair 2x 4gb DDR3
Motherboard onboard
AOC 831W & BenQ E900W (Digital)
1440x900 & 1366x768 (respectively)
Western Star Digital Internal SATA
Samsung Internal SATA
(Another unknown manufacturer) Internal SATA
Toshiba External USB 3.0
Fan.
Logitech G510
AVG Free
Upgrade your drivers, which version of windows are you running? I had a similar problem with a Sound Blaster card when I moved from 32 bit to 64bit windows, that turned out to be a driver issue.
windows 7 ultimate 64 bitAMD 1090T X6 Black Edition8 Gig geil Black Dragon 1600mzhSaphire ATI 5770 1 Gig DDR 5
Asus Formula IV Republic Of Gamers
Creative Soundblaster XFI
22'' NEC Multisync x 2
1 TB Sata
Thermaltake Blue Series 850w Modular
Antec 9002
Standard
MS Sidewinder
Logitech 518
4mbs
This was a self build which for the most part runs really well
My version of Windows is linked in my system specs and under my name.
I updated my drivers first. The ones on the site are apparently of an older version than the ones on the CD that came with the card. So drivers isn't the issue.
Asus Sabertooth Z77
Corsair 2x 4gb DDR3
Motherboard onboard
Fan.
Logitech G510
AVG Free
There are many posts on here about the crackling problems. Look over the posts and see if anything pertains to your installation. Crackling can happen with any sound card or integrated audio chip.
I notice you list Realtek audio. Since you have a separate SoundBlaster sound card, make sure the RealTek is disabled in the BIOS as it potentially can conflict with the SoiundBlaster.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Yes, I also disabled my onboard audio chip, both at the BIOS level and also uninstalled any unrelated audio drivers. I've done all the basic things like that, but still no fix in sight.
Asus Sabertooth Z77
Corsair 2x 4gb DDR3
Motherboard onboard
Fan.
Logitech G510
AVG Free
Doing a search for this sound card shows it's a very inexpensive (and old model) sound card. Although it should work OK, I wouldn't expect much more than "you get what you pay for".
If you are using wi-fi, disable that and see if it makes a difference. Video can cause this problem (try a different version driver). Wireless keyboard/mouse can is another potential area. The shared IRQ that the sound card is on can be an issue, etc.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Okay, so $25 for a soundcard isn't much then? Anyway, I don't have any form of wireless capabilities or devices in use or idly sitting around either...
Asus Sabertooth Z77
Corsair 2x 4gb DDR3
Motherboard onboard
Fan.
Logitech G510
AVG Free
Hmmmm, no one? nothing? I'll have to find some way to sort this out myself I suppose...
Asus Sabertooth Z77
Corsair 2x 4gb DDR3
Motherboard onboard
Fan.
Logitech G510
AVG Free
