Sony vaio no sound through hdmi
sweetpea
2:28 AM
I have a sony vaio VGN-ARN61E, which originally came with windows vista, but i have since upgraded to windows 7 home premium 32 bit. I have recently got a flatscreen tv and would like to be able to watch stuff streamed on my laptop on the tv. I have a hdmi cable (which claims to do both audio and video) and my laptop manual says that the hdmi port is for audio and video. however, when i plug the tv in, i get video but no audio. (so the audio still comes from my laptop speakers)
On my sound devices, a hdmi device is listed, but i cannot configure it, and when i play the test sound i get the error message "playback failed" if i select the hdmi device as my default device, then i get no sound at all.
I read online somewhere that i needed to upgrade my graphics card driver. I seem to remember (and think I also came to this forum for advice) that when i first upgraded to windows 7, i had a bit of a problem forcing the computer to recognise the nvidia graphics card driver. On nvidia online, the latest update for my graphics card (Geforce 8400M GT) includes a HDMI audio driver. However, this update is not suitable for sony laptops :confused: and when i try and install it, it says no suitable hardware was found.
I would appreciate any help with this problem, as I have tried everything I can think of, and it is starting to bug me now!
Many thanks in advance for any help
Ezme
Windows 7 Home Premium 32 bitIntel Core 2 Duo Procesor T54502GB/Go DDR2 SDRAMNvidia GeForce 8400M GT CPU
Sony Vaio VGN-AR61E
2GB/Go DDR2 SDRAM
Unfortunately, if Sony does not provide the drivers then it wont work. There may be some work-around for it, but I don't know of one.
This is quite a major and all too common problem with a lot of "Brand Name" machines. They are fine until you want to change or upgrade something.
If you do a quick Google search on "sony vaio VGN-ARN61E HDMI", you will find that lots and lots of people have the same problem.
This MIGHT!!! work;
http://esupport.sony.com/CA/perl/swu-download.pl?mdl=VGNFW140D&upd_id=3625&os_id=28
Regards....Mike Connor
Several, including Windows 7 x64 Ultimate
Windows 7 Ultimate SP1Intel Core 2 Duo P7450 2.13GHz4GB DDR2ATI Mobility Radeon HD 4650 Graphics
Sony VGN-FW520D
4GB DDR2
1600x900
500 GB SATA 5400 RPM
