USB SOUND CARD ISSUE
dreamcast
9:01 AM
i just purchased this usb 3d sound card and to my suprise it detects as plug and play on windows 7 without any driver disc... the shopkeeper states its windows 7 compatible.. but somehow on the box it isnt mentioned...:(
has anyone tried this device..
::COMODOW::
I get a time out when trying to access your link.
Windows will get drivers (on line) for many devices and this sounds like what it did for your sound device.
If you are going to use this rather than the existing sound you have and it's integrated (on the motherboard) you should disable the integrated sound in the BIOS to avoid conflicts.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
done that aswell bro.. and guess what ?? it works like a charm on Win XP~!
I don't get what the problem is. You stated in the original post that Windows detected it as a plug and play device. To me that means it's working.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Go to the Control Panel/Hardware and Sound and finally the Sound Panel. In the playback, make sure your USB sound is selected as the default playback device. The click on Configure button and test the speakers, to see if it's working at this point.
I also saw THIS on the web about it. Not too encouraging.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Fireberd - I am using a USB DAC on my computer and am having sound issues (drop-outs every few minutes.) How do I disable the integrated sound on my BIOS to avoid conflicts?
Windows 7 professional 64bitQuad Core X5677 3.46ghz12gbnVIDIA Quadro 2000 1gb
Dell Precision T5500
12gb
1.5tb 3.0Gb/s 7200 RPM 32mb DataBurstCache
Raid 1
There should be an entry in the BIOS - F2 Setup at power on. The Dell manual does not detail how to disable the on-board audio but on other models there is an entry for "Integrated Audio" or may say "Legacy Audio" or may have some other reference.
Take a look at the Setup. HERE is what is in the manual
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Thanks for the info, I'm willing to try anything!
12gb
Raid 1
