Sound Test works, but speakers wont work
The Problem:
when I do a sound test, I can hear the audio in the speakers. However when I try to play a midi file, or a DVD, the movie plays, but NO SOUND.
Usually if the sound test works, the audio plays in the speakers. So I am not sure what is happening here.
The History of the issue:
I Upgraded my emachine from Vista to Windows 7. I went to the Emachine website to update the audio drivers. The drivers that Emachine has are outdate.
I went to the Realteck website and downloaded the newest drivers.
I noticed in the device manager that their is a NVIDIA High Definition Audio, and a Realtek High Definition Audio listed.
Ok, so here is the setup.
I have a HDMI Visio TV plugged into the Emachine. Audio workes fine if I disable Realtek High Definition Audio in the device manager.
Here is the big problem: When I plug a simple set of speakers (that work on other computers) into the back of the computer, the audio will not work on the speakers.
If I enable the Realtek audio in device manger, I can get the Realteck audio options screen. Where Realtek sees that I plugged the speakers in the rear of the machine.
Can anyone advise.
