Sound Test works, but speakers wont work
carlpopp
11:48 PM
The Problem:
when I do a sound test, I can hear the audio in the speakers. However when I try to play a midi file, or a DVD, the movie plays, but NO SOUND.
Usually if the sound test works, the audio plays in the speakers. So I am not sure what is happening here.
The History of the issue:
I Upgraded my emachine from Vista to Windows 7. I went to the Emachine website to update the audio drivers. The drivers that Emachine has are outdate.
I went to the Realteck website and downloaded the newest drivers.
I noticed in the device manager that their is a NVIDIA High Definition Audio, and a Realtek High Definition Audio listed.
Ok, so here is the setup.
I have a HDMI Visio TV plugged into the Emachine. Audio workes fine if I disable Realtek High Definition Audio in the device manager.
Here is the big problem: When I plug a simple set of speakers (that work on other computers) into the back of the computer, the audio will not work on the speakers.
If I enable the Realtek audio in device manger, I can get the Realteck audio options screen. Where Realtek sees that I plugged the speakers in the rear of the machine.
Can anyone advise.
Windows 7 Ultimate (32 bit)
Emachine
Vizio HDMI
Wester Digital SATA
Ok, I found the problem, and wanted to share. I was using a VGA extension cable to connect the computer to a 55" LCD TV across the room. I noticed during trouble shooting that the left pin, on the second row of the VGA extension cable was pushed back. When I oulled the pin out, and reconnected the VGA cords, the sound worked GREAT. I have no idea what a video cord has to do with audio, but it worked. If anyone knows the teck on this issue, please shoot me the understanding. Thanks for this site!
Emachine
Vizio HDMI
Wester Digital SATA
