Confuse on Audio Issue...
ZakRhyno
I'm been reading about Windows 7 audio issues from different sources but never understood how they could help me with my problem. I'm using a software that recored from audio sources, in the soundcard area it shows devices which I selected mine and the only input source I can selected is Master Volume. Now from my reading if my sound card don't support streaming audio or something like that I can install a audio card. Alright I done that and it works, but the issue is in the software it see the other sound card but still the input is only Master Volume. So I guessing this is more of windows issue a not allowing me to choose my USB mic or other devices. I can use my devices in other means and they all work fine. I just don't know hos this works with Windows 7 and ask if anybody can give a hand.
thanks
Zak
Go to sound control panel.
Go to recording tab of that panel.
Right click in a blank area of that tab.
Make sure "show disabled devices" and "show disconnected devices" are checked. Can you then choose your device?
What recording program are you using? Audacity?
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
I can choose my device which is already set to. I use PodProducer as you can recored, edit, RSS and FTP as well as edit after show. Thus it beats Audacity 10 fold. :) PodProducer But I'm still having the same issue.
