Windows 7: Low sound after SP1
14 Apr 2011   #1
Windows 7 64bit
Low sound after SP1
I have 3 computers that have sound issues after SP1 for win7 was installed. The sound is stuck at -80% and the settings in the communications tab do not affect anything. Loudness EQ in the Enhancements does very little to help. Setting all the volumes sliders to max and the equalizer to max is what I have now. SRS sandbox helps a little but the sound is way too low at any speaker setting.
I have tried all the drivers for the realtek onboard sound chip for win7, only result was one of the computers lost all sound. The AMD 5850 video cards sound over the HDMI works fine with full volume on all computers.
I installed linux on a HDD and that almost blew out my ears! The sound was the way it used to be on Win 7.
I need a reg patch to increase all sound volume 200% in Windows 7.
All three computers are:
Windows 7 64 Home
Intel DG55KG mainboard with i7 860 cpu
XFX 5850 videocard with Acer S243HL LCD
Seagate 1.5 TB Hdd
8 gigs Sector 5 ram
750 watt power
15 Apr 2011   #2
Windows 7 Home Premium 64 bit
Assuming you have the latest driver installed from here......
On the communciations tab, have you tried "Do Nothing".
It may increase the volume.
23 Apr 2011   #3
Windows 7 64bit
Low sound volume fix works 100%
I found the fix for low sound volume in win 7 64, uninstall it, install free linux...
Can anyone increase the volume ovrall in windows 7 64?
I have tried ALL the drivers that will work for realtek on Intel DP55KG. (I used driver cleaner inbetween)
It was something in the updates that made the sound drop at the beginning of the year, all of last year I could damage my ears with my sound turned up to 3 on the knob, not now.
I see the settings in the levels tab goes DOWN to -62 db and ONLY up to +2db, I need to be able to reverse that.
All 3 computers have this issue, they are in different locations and one has AMD cpu, same realtek crap sound chip.
Now if they were fine for a year, then this year at around March they start to drop sound volume, what caused it?
Can anyone make me the reg code, so i can just merge it, and have the -62 to +2db reversed? I get total mute at -18 db, so why go all the way down to -62? Hell just add a 0 and have it go to +20db. Is it possible?
24 Apr 2011   #4
Microsoft MVP
Windows 7 Ultimate 32bit SP1
See this post and configure your speakers Low sound volume
06 May 2011   #5
Windows 7 64bit
I have tried all drivers that will work. Still low sound.
Still stuck? any help? Windows auto "updates" I mean auto breaks itself when connected to the web.
 Low sound after SP1
Search this Thread:
Advanced Search
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
