Windows 7: Microphone volume won't stay put
17 Apr 2011   #1
Windows 7 home premium 64 (I Think)
I want to lower my microphone volume from 100 to 50. When I do it, it will stick around for a little while (while I record something), but then it will jump back to 100 sometime after I'm done or even before I start. For some reason, the adjustment just won't be saved. I'm hitting OK to close the menus, so that isn't the issue. Here is a screenshot of the menu I am using:
Capture.png picture by Wyrd5 - Photobucket
I am trying to keep the top bar at 50, but it just won't stay put. Can anyone help me? Thanks.
17 Apr 2011   #2
Win 8 Release candidate 8400
Quote   Quote: Originally Posted by Wyrd View Post
Does whatever app you are using have an "auto-adjust mic"????
17 Apr 2011   #3
No, it doesn't seem to. I am using fraps, and the only audio option in it are 2 check boxes, Record Windows 7 Sound and Record External Input, both of which are checked to indicate yes.
18 Apr 2011   #4
It's a thing you may have already enabled in the 'Advanced' tab. There should be 2 options named 'Give exclusive mode applications priority' and 'Allow applications to take exclusive control of this device' uncheck both options (Or try one and not the other). The app will try to automatically adjust the sensitivity of the microphone, in order to increase when you are not loud enough, and decrease when you're too loud.
Hope this helps
18 Apr 2011   #5
Sorry it took so long to reply, I had to test it. Unfortunately, no, it didn't work, but I appreciate the help. Any other ideas? =]
19 Apr 2011   #6
Not sure then. Maybe you could record with Audacity and Fraps, so you have 2 different streams you can edit.
Similar help and support threads for2: Microphone volume won't stay put
Microphone volume too low Sound & Audio
Solved Microphone volume is agonizingly low Sound & Audio
Microphone volume reduced Sound & Audio
Microphone volume unusably quiet under Win 7. Sound & Audio
External Microphone Volume goes low automatically Sound & Audio
Does program for microphone volume exist? Sound & Audio
Microphone volume meter for taskbar? Software
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
