Using Chrome : Fuzzy Noise / Crackle
Page 1 of 3 123 LastLast
  1. Posts : 25
    windows 7 64bit
    I'm on my HP laptop and when i use chrome my noise is fuzzy and crackly and just unbearable
    I tested it and the sound is perfect when i close chrome. but then when i opened it back up it was bad :'(
    EDIT: Having this same problem using internet explorer 9
    EDIT: It seems it happens if i do anything stressful to the computer
  2. Posts : 9,537
    Twitty,
    Try putting a music CD or you tube and see if your speakers are malfunctioning.
  3. Posts : 25
    windows 7 64bit
    The Howling Wolves said:
    Twitty,
    Sorry, what? And i also have this problem if i plug my headphones in -____-
  4. Posts : 9,537
    Does the problem occur just when browsing or could if be your laptop speaker's going bad?
  5. Posts : 25
    windows 7 64bit
    It happens when just browsing or really doing anything i think because i exited out of chrome completely, played some music and it was fine. when i clciked chrome it just totally crackled up and came to a point where i had to turn it off..
    it also happens if i do something else i think because it happens a little bit if i just drag the corners of itunes to make it bigger :/
    edit: just not as bad. maybe just a little bit of pop
  6. Posts : 2,528
    Windows 7 x64 Ultimate
    Sounds like your sound driver is not doing so well, failing any time there is any significant load on your system. Might try figuring out what sound device you have and downloading the official driver from the manufactuerers website...
  7. Posts : 9,537
    How about trying another browser, Firefox, Opera, or whatever to see if it happens there?
    How are you hooked up to the internet? Maybe a bad cable or connection problem. IMHO
  8. Posts : 25
    windows 7 64bit
    I clicked update drivers but it says its up to date. is there a way i can get a different one?
  9. Posts : 25
    windows 7 64bit
    I tried Opera. The same thing happens but its less extreme. At some points its actually perfect. but if i go to a link or new tab it happens. it could just be because chrome is taking a lot more memory? idk
  10. Posts : 2,298
    It may be a Wireless Connection problem - Some Speakers pick up interference between Wireless connections - Does this happen whenever you use your Wi-Fi?
    Have you tried surfing with an Ethernet Cable plugged in? If so do you recieve the Same issue?
    Edit: I notrious interference is with Mobile Phones and older speakers producing beeping sounds
    Many Thanks,
    Josh
