ALC 888 // No audio output device is installed
mikn58
2:37 AM
hello all. recently i've incountered an audio driver issue. i have an ALC 888 soundcard from Realtek. one day i left my computer on overnight charging my phone via usb. when i turned the screen on, the volume icon on the bottom right had a red cross on it and i couldnt run anything audio related including itunes..... i googled a ton and couldnt come to a solution. i tried updating, uninstalling, reinstalling, drivers.
at first, when i went to device manager, instead of seeing 'Realtek High Definition Audio Output' (which i think is supposed to say), i saw 2 listed. it was 'high quality bluetooth audio' and 'bluetooth audio' i managed to update the drivers manually, by making it browse my C: drive. everything worked as it should and the icon on the bottom right was corrected. but my speaker and earphones wouldnt work. my itunes and audio related files were running correctly at this point with no errors; just no output. so i uninstalled both bluetooth highquality audio devices and deleted the update file for it that was in my C: drive. as of now, when i go to device manager, there is no 'sound, video, blah blah' option. and the red cross is BACK!!!!!!!!!!!!!! please help :cry:
Windows 7 Ultimate x86AMD Athlon(tm) 64 X2 Dual Core Processor 4800...2GBNVIDIA GeForce 6150SE nForce 430
HP-Pavilion RX887AA-ABA a6030n
AMD Athlon(tm) 64 X2 Dual Core Processor 4800+, 2.5GHz
ECS Nettle 1.0
2GB
HD Audio Device; now its gone.
19.1"
1440 x 900 @ 60Hz
Have you tried a System Restore to a date prior to when this all started?
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
yes. it didnt change a thing :(
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
