No audio output device installed
Page 1 of 3 123 LastLast
  1. Posts : 20
    Win7 Pro 32bit
    Hi all,
    In the taskbar I have a volume-icon with a red cross on it. When I go to this icon, "No audio output device installed" appears.
    I have a Intel Corporation DQ965GF mainboard with onboard sound.
    When I go to Control panel -> sound, everything is gray and not clickable.
    In Device Manager, I found "file as volume driver", "volume manager" and "high definition audio controller", under system devices. Nothing else...
    I searched on the intel website but did not find a solution or drivers...
    Can someone help me, because atm I have no sound.
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Make sure that in the BIOS, that the on board sound is turned on.
  3. Posts : 20
    Win7 Pro 32bit
    Bios settings are:
    Audio: Enabled
    High Definition Front Panel Audio: Enabled
  4. Posts : 9,606
    Welcome babbelut
    Could you give us a screen snip of Device Manager & Sound expanded ?
    Attached Thumbnails Attached Thumbnails No audio output device installed-device_manager_sound.jpg
  5. Posts : 20
    Win7 Pro 32bit
    I can't because in device manager there is no "sound, video and games controllers"
  6. Posts : 1,996
    It could be that the audio driver is no longer installed.
    Right click on "high definition audio controller" > Properties > Details > Property and select Hardware Ids.
    Post a picture using the snipping tool.
    Example
  7. Posts : 20
    Win7 Pro 32bit
  8. Posts : 1,996
    First, re-install your chipset drivers from here.
    http://downloadcenter.intel.com/Deta...&DownloadType=
    Post a snip of your device manager (Sound, video....items) after installing.
  9. Posts : 20
    Win7 Pro 32bit
    after installing
    Attached Thumbnails Attached Thumbnails No audio output device installed-snip2.png
  10. Posts : 1,996
    Try this
    It may work best with IE
    Intel® Driver Update Utility
