No sound with onboard audio
  1. Posts : 49
    Windows 7 Pro 64bit
    Using Windows 7 64 bit. Have ASUS M4A79XTD board with onboard audio. Everything has been running great. There were no changes or upgrades done yesterday. There was a power failure at my house for a second and when it booted up it asked do you want to start up as usual or in safe mode etc. Ever since I get no sound. I see the audio waves in media player. Also the sound controls show meters moving up and down. I got the latest VIA audio driver. Anyone have any other suggestions?
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Do you have the default set to "Speakers"
  3. Posts : 49
    Windows 7 Pro 64bit
    Yes I have the speakers set as default.
  4. Posts : 2,039
    Several, including Windows 7 x64 Ultimate
    Power failures can cause severe problems with various things. It may have killed your speaker amplifiers.
    Check to make sure that you have the volume turned up, and not "Muted".
    Regards....Mike Connor
  5. Posts : 1,996
    The only thing I can think of, based upon what you mentioned, is that there may be something wrong with the levels.
    To check, go to the volume mixer > Playback devices > Speakers > Properties > Levels > Front.
    Make sure that the front level is at 100.
  6. Posts : 1,996
    mallen said:
    Yes, ASUS uses VIA, instead of Realtek on your particular board, so the setup is different. Check for additional settings on your VIA control panel, if you have the VIA driver installed. There may be a front volume setting on the control panel that may be lowered or muted. If not, try re-installing the driver from here. VIA Drivers Download - VIA Technologies, Inc.
  7. Posts : 352
    Windows Home Premium 64bit
    Hi Mallen and welcome back to the Forum. Sometimes a momentary power fluctuation can cause unexpected changes to Bios setting. Yes I have seen it more that once. On the outside chance, go into your Bios at startup - go to Advanced tab, then the On Board Device Congiguration tab, then Hd Audio Controller and make sure it is set to ENABLED.
    Just a shot - give it a try.
    Regards
    JohnnyA
  8. Posts : 49
    Windows 7 Pro 64bit
    I checked the BIOS and onboard audio was enabled. I disabled and then renabled it to see if that would help. Below that was a setting I was not sure about.
    Eup Ready- Allows BIOS to switch off some power at S5 state to get system ready for the Eup requirment. When set to ENABLED, power for WOL, WO_USB and audio will be switched at S5 state.
    Not sure what S5 state is????
    Also since the power got interrupted, maybe its "stuck" in some in between mode?
  9. Posts : 2,039
    WOL is "Wake on Lan" ;
    Wake-on-LAN - Wikipedia, the free encyclopedia
    WO_USB is "Wake on USB":
    Universal Serial Bus - Wikipedia, the free encyclopedia
    S5 is "Soft Power Off";
    G2 (S5), Soft Off: G2 is almost the same as G3 Mechanical Off, but some components remain powered so the computer can "wake" from input from the keyboard, clock, modem, LAN, or USB device.
    Advanced Configuration and Power Interface - Wikipedia, the free encyclopedia
  10. Posts : 2,039
    mallen said:
    What about these NVIDIA drivers. Should I try deleting these?
    Attachment 151424
    Use "Driver Sweeper" to remove all old installations before reinstalling;
    Phyxion.net - Driver Sweeper
