im just trying to run it threw pc i get picture no sound and how do u enable it on you tv unlesss i did already >
If you need help finding your system specifications, then download this;
Speccy - System Information - Free Download
Regards....Mike Connor
You need a driver like this to run sound on an ATI Radeon card HDMI interface;
ATI Catalyst
However, the driver will not do you any good if the device is telling you that it is not plugged in. Your posts are confusing. What device is not plugged in? If you have a picture, it must be plugged in!
If you have a picture and no sound then you need to install the sound driver from the above URL.
Speccy should show you something like this;
The AMD High Definition Audio Device, is the sound driver for the HDMI interface on your ATI Radeon card.
Operating System
MS Windows 7 Home Premium 64-bit
Intel Core i3 370M @ 2.40GHz 31 °C
Arrandale 32nm Technology
RAM
6.0GB Dual-Channel DDR3 @ 532MHz (7-7-7-20)
Gateway SJM70-CP (CPU 1) 33 °C
Graphics
SAMSUNG (1600x900@60Hz)
Intel(R) HD Graphics
Standard VGA Graphics Adapter
733GB Western Digital WDC WD7500BPVT-22HXZT1 (SATA) 24 °C
Optical Drives
HL-DT-ST DVDRAM GT30N
Audio
Sound Cards
ATI High Definition Audio Device
Playback Devices
Speakers (Realtek High Definition Audio) (default)
Realtek Digital Output (Realtek High Definition Audio)
Speaker Configuration
Speaker type Stereo
In your forum user interface, there is a section for entering your system specifications;
This makes it easy for anybody to check what you are using, and give you specific advice, just by clicking on your system specs at the bottom left of every post you send.
Having to jump back and forth between posts to find specs you entered in a post makes it difficult.
Sound Cards
it just saying it cant detect it but it says its enabled and working but it keep saying its not pluged in does it matter if i have a pc audio input in the back of my tv ?
