need help like mad going crazy
xxadosxx
10:41 AM
Canada
k so i have a samsung tv hooked the hdmi everyworks no sound i tryed uninstalling and reinstalling still says ati hdmi output not plugged in went to google did pretty much everything possible can anybody help ?:(
windows 7 x64Intel Core i3 370M @ 2.40GHz 32 °C Arrandale ...6 gb ddr3 memory
windows 7 x64
Intel Core i3 370M @ 2.40GHz 32 °C Arrandale 32nm Technolog
Gateway SJM70-CP (CPU 1)
6 gb ddr3 memory
Sound Cards ATI High Definition Audio Device Realtek High
Do you have the HDMI sound driver installed? This is an extra driver for many interfaces.
Unless you fill out your system specs, it is difficult/impossible for members to give you specific advice.
Regards....Mike Connor
Several, including Windows 7 x64 Ultimate
yeah i have it installed ive pretty much tryed everything googles been saying :(
windows 7 x64
6 gb ddr3 memory
Have you had this working before, or is this a new installation?
Do you have a display like this in device manager:
its always says not plugged in im just trying to get sound out of my lcd samsung it says its enabled and working
windows 7 x64
6 gb ddr3 memory
it just cant detect it for some reason ive been trying everything everyones been saying
windows 7 x64
6 gb ddr3 memory
ati mobility radeon hd 5650 1 gb vram intel core i3 370m 750gb hdd
windows 7 x64
6 gb ddr3 memory
Have you tried another cable? It is not unusual for a cable to be defective, and this of course results in an error which says it is not plugged in.
Also, have you enabled the HDMI input setting on the TV?
windows 7 x64
6 gb ddr3 memory
yeah the hdmi3 comes up but what does that have to do for the sound i get the picture just no sound
windows 7 x64
6 gb ddr3 memory
im just trying to run it threw pc i get picture no sound and how do u enable it on you tv unlesss i did already >
windows 7 x64
6 gb ddr3 memory
The HDMI interface requires a sound driver. The video works, but without a sound driver you get no sound.
Your system specs are here;
Fill them out properly and I might be able to find out what you need.
You need a driver like this to run sound on an ATI Radeon card HDMI interface;
ATI Catalyst
However, the driver will not do you any good if the device is telling you that it is not plugged in. Your posts are confusing. What device is not plugged in? If you have a picture, it must be plugged in!
If you have a picture and no sound then you need to install the sound driver from the above URL.
Speccy should show you something like this;
The AMD High Definition Audio Device, is the sound driver for the HDMI interface on your ATI Radeon card.
Operating System
MS Windows 7 Home Premium 64-bit
Intel Core i3 370M @ 2.40GHz 31 °C
Arrandale 32nm Technology
RAM
6.0GB Dual-Channel DDR3 @ 532MHz (7-7-7-20)
Gateway SJM70-CP (CPU 1) 33 °C
Graphics
SAMSUNG (1600x900@60Hz)
Intel(R) HD Graphics
Standard VGA Graphics Adapter
733GB Western Digital WDC WD7500BPVT-22HXZT1 (SATA) 24 °C
Optical Drives
HL-DT-ST DVDRAM GT30N
Audio
windows 7 x64
6 gb ddr3 memory
Sound Cards
Playback Devices
Speakers (Realtek High Definition Audio) (default)
Realtek Digital Output (Realtek High Definition Audio)
Speaker Configuration
Speaker type Stereo
windows 7 x64
6 gb ddr3 memory
In your forum user interface, there is a section for entering your system specifications;
This makes it easy for anybody to check what you are using, and give you specific advice, just by clicking on your system specs at the bottom left of every post you send.
Having to jump back and forth between posts to find specs you entered in a post makes it difficult.
okay added it to my specs
windows 7 x64
6 gb ddr3 memory
Excellent. Thanks.
Now, please describe slowly and carefully what you have connected to what. And which devices are giving you errors.
Sound Cards
it just saying it cant detect it but it says its enabled and working but it keep saying its not pluged in does it matter if i have a pc audio input in the back of my tv ?
windows 7 x64
6 gb ddr3 memory
