mobo audio input help
ganjiry
Gamer
5:24 AM
Droitwich spa uk
hi all
just a quickie, not realy a problem just not quite sure lol.
i have just bought a new surround sound setup with 3 leads to conect 2 pc.
am i reading this right? the 3 inputs on my mobo are 1xmic 1xheadphone 1xaux.but wen using a surround system they all change 2 inputs for the speakers?
soz 4 being a dumb ass lol. just dont wanna kill anythin:doh:
thanx in advance 4 the help folks
Win7 Home Premium x64 SP1i7 4770k8Gb Kingston HyperX Beast 2400MHz @2133MHz 11...MSI GTX 780ti Gaming Oc x2
Custom build
i7 4770k
Asus maximus VI Hero
Onboard ROG SupremeFX
Asus VG248QE
3840X1080 144Hz
1x1TB hitachi storage
EVGA Supernova 1000w Platinum
Corsair Air 540
Corsair H100i
Coolermaster Quickfire Pro
Corsair M65 RGB
74mb dwn/16up
MSE,Malwarebytes
it looks that way - i dunno what you're supposed to do if you want to use the mike whilst gaming in 5.1 - is there not a mike input on the front?
it seems to be a trend amongst hardware designers to double up the 'ports' like that - for instance, on my netbook, the same jack socket is used for headphones and mike. you have to buy a special gizmo if you want to use both at the same time. is it really an economy thing - how much money do they really save by not giving us extra sockets?
don't worry, you shouldn't break or fry anything if you stick it into the wrong hole...;)
*edit* re-reading your post, you haven't got three inputs? speaker sockets are 'outputs'. maybe i'm being pedantic, but there is an important distinction. :geek:
ultimate 64 sp1i5 2500K [email protected]8 gigs GSkill Ripjaws 1600amd hd6950
mickey megabyte 1234
ultimate 64 sp1
MSI P67A-GD53
amd hd6950
creative x-fi gamer
samsung 24"
antec 550
antec three hundred
i'm a cooling fan
saitek eclipse ii
logitech g3
about 4 Mbps
i love win7
hi mikey, cheers 4 the quick reply. as for the mic i can use the front mic input. im pretty sure i can enable it in via deck.
wot do u mean by where did i get the idea there is 3 inputs? u mean on pc or surround speakers?
the 3 inputs on the mobo r in the pic and there r 3 jack plugs either end of lead.
u pickled me lol
edit just clocked ur edit. lol! got me thinking then. i know they r outputs but is was just the word i chose lol as im gonna input the jacks.:D
cheers 4 the help, much apreciated
Custom build
i7 4770k
Asus VG248QE
3840X1080 144Hz
Corsair Air 540
Corsair H100i
Corsair M65 RGB
74mb dwn/16up
MSE,Malwarebytes
hi all
That's correct. But you should try not to confuse inputs and outputs.
By the way, did you see Stormy's reply to your other question? ;
http://www.sevenforums.com/sound-au...-apps-through-headset-n-speakers-2gether.html
Regards....Mike Connor
Several, including Windows 7 x64 Ultimate
hi mike cheers
yeah i know the sketch with ins n outs lol. i just said inputs for less typin. rather than each 1. the pic explained so i didnt.
my apologies.
as for the other post. nah i had'nt seen stormys post but hav just replied. im waiting on delivery of a sound card so holding back on that 1.
thanks 4 ur help folks:D
Custom build
i7 4770k
Asus VG248QE
3840X1080 144Hz
Corsair Air 540
Corsair H100i
Corsair M65 RGB
74mb dwn/16up
MSE,Malwarebytes
