need the right sound driver! FAIL!~!
mikn58
4:16 PM
I've tried alot of drivers for my sound card but none of them worked for me.
the links are outdated on that PCI website and i've been trying to fix this shit for 2weeks. :( I am running Windows 7 Ultimate 32bit on HP a6030n and my sound card is ALC 888
Here is my id info for my audio card so if somebody could help me find the right driver that would be great.
PCI\VEN_10DE&DEV_03F0&SUBSYS_CB8410DE&REV_A2
PCI\VEN_10DE&DEV_03F0&CC_040300
Windows 7 Ultimate x86AMD Athlon(tm) 64 X2 Dual Core Processor 4800...2GBNVIDIA GeForce 6150SE nForce 430
HP-Pavilion RX887AA-ABA a6030n
AMD Athlon(tm) 64 X2 Dual Core Processor 4800+, 2.5GHz
ECS Nettle 1.0
2GB
HD Audio Device; now its gone.
19.1"
1440 x 900 @ 60Hz
Windows 10 Pro x64, Arch LinuxIntel Core 2 Quad Q8200 OC'd 3.08GHz8GB DDR2 900MhzMSI GT730 2GB GDDR5 (Kepler)
Asus Rampage formula LGA775
8GB DDR2 900Mhz
Supreme FX2
Samsung LS22F350 LED
1080P
Kingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch)
AeroCool 500W Bronze
Cooler Master V6 + 3X fans
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
Did you remember to install the chipset drivers? Most times a lot of other things won't work properly without them. Unfortunately that HP of yours has one of the old Nforce 4 based chipsets on it,
Motherboard Specifications, MCP61PM-HM (Nettle) HP Pavilion a6030n Desktop PC - HP Customer Care (United States - English)
that there is limited to no support for in Windows 7 because Nvidia dropped support for it shortly after Vista came out (bet you also have a coprocessor with a yellow triangle showing in Device Manager as well). There is however a Vista chipset driver,
NVIDIA DRIVERS 15.49 WHQL
that should work. It may take compatibility mode to get it to install,
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
Get the chipset driver installed and the audio driver should then install.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
thankyou! i will report back as soon as i try it :)
EDIT: ok. am i supposed to see a change in device manager after i install the nvidia drivers? cuz i didnt see any changes.. but i went ahead and ran the driver that yowanvista posted and it didnt seem to work.
Heres a screeny of my Device Manager:
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
One good reason for the driver failing, there is nothing showing at all for "Sound, video, and game controllers" to the point that the entire category is missing. Might want to have a quick look in the bios and make sure that the onboard audio is enabled.
P.S. You can use it if you want but the driver yowanvista is somewhere around 2 years old and has been updated numerous times since then.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
ok so to get into my bios to check, do i restart my comp and press a key?
EDIT: my bios shows me nothing related to audio except Audio Codec.
the choices are disable, enable, or auto. it was set on auto so i set it to enable but nothing happened...
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Leave the option set to Auto. Download the current driver from Realtek - see: http://www.sevenforums.com/sound-audio/3756-latest-realtek-hd-audio-driver-version.html and follow the instructions here: Device Manager - Install Driver - Vista Forums to install the driver. I recommend that you download the zipped version of the driver, extract it and then then browse to the extracted files in Step 10 of the above Tutorial.
yesss but to do that, i need the sound, video, game controller tab in my device manager. it's missing!
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
Any unknown devices showing in Device Manager?
The "high definition audio controller" showing under System Devices is the generic Microsoft driver, and gets installed on all systems regardless of what sound card is used.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
i expanded all columns and there was no unknown device. say about a week ago, i was trying to fix it on my own, and i read it somewhere to uninstall the stuff in sound, video, game controllers column. so i uninstalled it, and deleted the driver too. they were 'Bluetooth Audio', and 'Bluetooth High Quality Audio'.
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
Try this!!
I've had this problem before and found this cool little program on another forum...
It's called 3DP chip, it identifies your chipset and hardware and gives you a direct link to the url for download of the proper driver..
:: 3DP Chip :: 3DP Software (3DP Chip / Net / Bench)
Hope that helps!
Windows 7 Home Premium 64bit.
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
Unless you added something that uses bluetooth for audio, I think it is safe to say that what you deleted was being mis-identified as I don't see anything in the specs for your computer,
HP Pavilion a6030n Desktop PC Product Specifications HP Pavilion a6030n Desktop PC - HP Customer Care (United States - English)
Let's try something different to see if it has ever been shown in Device Manager. Set Device Manager to show hidden and ghost devices,
http://www.sevenforums.com/tutorials/77614-device-manager-hidden-devices.html
an hopefully it will show something to do with the onboard sound.
P.S. One quick question. Are you still using the onboard video or have you added a video card? If you have added a video card, what is the make and model?
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Ok, i made it so that it shows hidden devices.
the 3 new things that i'm seeing is,
-Storage Volume Shadow Copies
-Storage Volumes
-Non-Plug and Play Devices
HERES what it looks like when i expand the 3 of them:(in order from top to bottom)
And, no. i believe i am using the onboard video.
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
can anyone help me?
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
sorry to triple-post but i've had this issue for 2 1/2 MONTHS!! can anyone please help me find me my "sound, video, and game controllers" back in my device manager? i've had it once before now its GONE! and its NOT hidden. just completely gone.
ECS Nettle 1.0
2GB
19.1"
1440 x 900 @ 60Hz
