Windows 7: need the right sound driver! FAIL!~!
29 Apr 2011   #1
Windows 7 Ultimate x86
I've tried alot of drivers for my sound card but none of them worked for me.
the links are outdated on that PCI website and i've been trying to fix this shit for 2weeks. I am running Windows 7 Ultimate 32bit on HP a6030n and my sound card is ALC 888
Here is my id info for my audio card so if somebody could help me find the right driver that would be great.
PCI\VEN_10DE&DEV_03F0&SUBSYS_CB8410DE&REV_A2
PCI\VEN_10DE&DEV_03F0&CC_040300
29 Apr 2011   #2
Win7 Ultimate SP1 x64 / Windows 8 Pro / Android
Mauritius
Try this driver
29 Apr 2011   #3
Win 7 Ultimate x64
Etobicoke, Ontario
Latest Realtek HD driver can be found here,
Latest Realtek HD Audio Driver Version
29 Apr 2011   #4
Quote   Quote: Originally Posted by yowanvista View Post
Try this driver
ok trying right now. do i update it and choose that file?
EDIT: I ran the setup.exe but no luck... i've tried most ALC888 related drivers out there
Quote   Quote: Originally Posted by stormy13 View Post
i tried this one no luck
29 Apr 2011   #5
Win 7 Ultimate x64
Etobicoke, Ontario
Did you remember to install the chipset drivers? Most times a lot of other things won't work properly without them. Unfortunately that HP of yours has one of the old Nforce 4 based chipsets on it,
Motherboard Specifications, MCP61PM-HM (Nettle) HP Pavilion a6030n Desktop PC - HP Customer Care (United States - English)
that there is limited to no support for in Windows 7 because Nvidia dropped support for it shortly after Vista came out (bet you also have a coprocessor with a yellow triangle showing in Device Manager as well). There is however a Vista chipset driver,
NVIDIA DRIVERS 15.49 WHQL
that should work. It may take compatibility mode to get it to install,
Compatibility Mode
Get the chipset driver installed and the audio driver should then install.
29 Apr 2011   #6
Compatibility Mode
thankyou! i will report back as soon as i try it
EDIT: ok. am i supposed to see a change in device manager after i install the nvidia drivers? cuz i didnt see any changes.. but i went ahead and ran the driver that yowanvista posted and it didnt seem to work.
Heres a screeny of my Device Manager:
29 Apr 2011   #7
Win 7 Ultimate x64
Etobicoke, Ontario
One good reason for the driver failing, there is nothing showing at all for "Sound, video, and game controllers" to the point that the entire category is missing. Might want to have a quick look in the bios and make sure that the onboard audio is enabled.
P.S. You can use it if you want but the driver yowanvista is somewhere around 2 years old and has been updated numerous times since then.
29 Apr 2011   #8
ok so to get into my bios to check, do i restart my comp and press a key?
EDIT: my bios shows me nothing related to audio except Audio Codec.
the choices are disable, enable, or auto. it was set on auto so i set it to enable but nothing happened...
30 Apr 2011   #9
Windows 7 Ultimate x64 Service Pack 1
Doncaster, UK
Leave the option set to Auto. Download the current driver from Realtek - see: Latest Realtek HD Audio Driver Version and follow the instructions here: Device Manager - Install Driver - Vista Forums to install the driver. I recommend that you download the zipped version of the driver, extract it and then then browse to the extracted files in Step 10 of the above Tutorial.
30 Apr 2011   #10
Quote   Quote: Originally Posted by Dwarf View Post
yesss but to do that, i need the sound, video, game controller tab in my device manager. it's missing!
 need the right sound driver! FAIL!~! problems?
Similar help and support threads for: need the right sound driver! FAIL!~!
G-force 8400 gs driver fail Graphic Cards
Dazzle Card Driver installation Fail Drivers
Webcam Driver Open Fail Drivers
Webcam driver open fail. Please restart ... Drivers
D&D Online weird Sound Driver fail Gaming
