headphones mode audio problem
slovakftw
7:08 AM
Recently upgraded from xp and i feel like an idiot for upgrading. so i am using an creative xfi fatality sound card and there is no plug to connect to front audio ports. I am trying to get my headphones to work under headphone mode and not speakers.
now my problem is when i go to playback options in windows7 i am given speakers which is enable, and headphones which are disabled. the headphone mode under advanced tab only has the front jacks under jack information. i tried going to advance on speakers but i am only given modes like stereo 5.1 and 7.1.
so basicly i want the ability to plug in my headphone to my sound card in the back n get the nice directional sound i had in XP.
windows7 64bit
windows7 64bit
slovakftw, welcome to the Seven Forums.
You can't make the changes you want in the Windows audio properties, it has to be done in the X-Fi controls. If all you installed for the card was the drivers you should have this,
where you can set the card to headphone mode, and then enable or disabled CMSS3D, which is what you are looking for. Alternatively if you didn't install it you can find the Console Launcher (which has all the settings as the above control panel and a few more),
You can find the latest version here,
Creative Worldwide Support > Sound Blaster
Locate your card, then click on "beta application" and download the Console Launcher. The beta is a fair bit newer than the last official release and works just fine (or at least I haven't come across any bugs in it on mine).
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
