sonicstage 4.3 help desperatly needed please
  1. Oni
    Windows 7 ultimate x86
    I have downloaded sonicstage 4.3 countless times but it will not install. It appears as it installs then asks me to reboot but nothing is in the install dir. I have also installed it and was actualy watching the install dir as it was ''installing'' but no files ever get installed. Please help i realy need this app.
    Many thanks in advance
  2. Posts : 867
    XP, Vista, W7 64bit Home Premium
    Have you tried running the install program as an administrator, and in compatibility mode with whatever OS it was written for : To install a driver/program in compatibility mode - right click the setup.exe file - click properties - click compatibility - check run in compatibility with xp/vista etc - check run as administrator - leave the rest blank. Start setup.exe and install.
