Volume Mixer Audio Output Indicator Gone
Joseph25
1:01 AM
You know when you are playing an audio file and you are able to see the current output volume of the song in the Windows7 Volume Mixer as a semi transparent bar behind the volume slider?
For some reason, mine is gone.
Also when I put headphones in my PC it is really loud and I have to keep my volume levels really low.
Please help me with my problem.
Windows 7 x64Core 2 Duo4 GB DDR2Nvidia Quadro NVS v140
Lenovo T61
Windows 7 x64
Core 2 Duo
4 GB DDR2
Soundmax
XP, Vista, W7 64bit Home PremiumIntel Core Duo 6850 3.0 ghz @ 3.7 ghz4GB Corsair DDR 2 PC-6400Ati 4870 1ghz
Asus P5E
Ati 4870 1ghz
Supreme FX 11
View Sonic VX1962wm
1680 X1050
3 Seagate Sata Drives 160gb 250gb 500gb
Thermaltake 600 watt
NZXT Alpha
3X120cm Fans
Microsoft Digital Media Pro Keyboard
Microsoft Wheel Mouse Optical
1.5Mb to 8Mb/384k
