Sound help
  1. Posts : 9
    Windows 7 Ultimate x32
    Sound help
    Hi.
    I have a ASUS m70sr and the sound does not work.
    The startup sound and external sound works. Iwe tried everything. Downloaded loads and loads of different drivers.
    I'm sorry if the solve is on the forums but i have looked around for ages and im satrting to get nuts
  2. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
    Do you have external speakers?
  3. Posts : 9
    No. i have a headset.
  4. Posts : 1,794
    MS Windows 8
    hi deralnocor, in Asus driver support site it only shows vista driver for 32 bit. have you checked this:
    ASUSTeK Computer Inc. -Support- Drivers and Download M70SR
    before installing new drivers you should remove the previous ones. use Driver Sweeper it is a program that will remove leftovers from key drivers, namely graphics and sound.
    https://www.sevenforums.com/software/...r-2-1-0-a.html
  5. Posts : 9
    i tried to do this but when i tried to install the windows vista drivers i got the
    "no driving circuit was supported in this drive circuit package" roughly translated.
    and now not even my headset works. . .
  6. Posts : 1,996
    Windows 7 Home Premium 64 bit
    You may want to try the Windows 7 driver from here. Realtek
    If it doesn't work, try using the Vista driver, you may have to run it in compatibility mode. Compatibility Mode
  7. Posts : 9
    I tried this before. did not work, but do you think it will work since i used the sweeper?
    And which vista driver do you mean? the Realtek or the Asus?
    I allready tried the asus driver in compatibility mode.
    And what should i do if a driver does'nt work should i use the sweeper again? can this be a source to that the 'new' driver does'nt work?
  8. Posts : 8,608
    Have you tried setting the Realtek High Definition Audio device to be the default for your headset?
  9. Posts : 9
    What do you mean?
    As you can see on the picture i have the Realtek High Definition Audio Speakers as Standard.
    And the relatek HD drivers did not help...
  10. Posts : 9
    I just went into the device manager and i uninstalled everything under sound and rebooted, then i tried to install the relatek HD drivers again but windows automatically installed the same as i installed just before...
    can this be the problem?
