Sound help
Deralnocor
12:48 AM
Hi.
I have a ASUS m70sr and the sound does not work.
The startup sound and external sound works. Iwe tried everything. Downloaded loads and loads of different drivers.
I'm sorry if the solve is on the forums but i have looked around for ages and im satrting to get nuts :cry:
Windows 7 Ultimate x32Intel Core 2 Duo T8100 / 2.1 GHz3 Gigabyte DDR2 SDRAM - 667 MHzATI Mobility Radeon HD 3470
Asus m70sr
Dolby Home Theater
17" TFT
250 GB - Serial ATA-150 - 5400 rpm
AC 120/230 V ( 50/60 Hz )
Do you have external speakers?
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
No. i have a headset.
Asus m70sr
Dolby Home Theater
17" TFT
MS Windows 8Intel Core i5 @ 2.27GHz Arrandale 32nm Techno...8.0GB Dual-Channel DDR3 @ 532MHz (7-7-7-20)ATI Mobility Radeon HD 4300 Series (Dell)
Dell inspiron 1564
MS Windows 8
Intel Core i5 @ 2.27GHz Arrandale 32nm Technology
Dell Inc. 0M9XW4 (U2E1)
Generic PnP Monitor on ATI Mobility Radeon HD 4330
1366x768 pixels
1 tb TOSHIBA (SATA)
built-in
Dell Laptop
built-in
built-in
Dell Touchpad/Microsoft Arc Mouse
Snake Laptop Skin, Detachable Alfa USB wifi with custom 15dbi antenna (for better signal range)
i tried to do this but when i tried to install the windows vista drivers i got the
"no driving circuit was supported in this drive circuit package" roughly translated.
and now not even my headset works. . .
Asus m70sr
Dolby Home Theater
17" TFT
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
You may want to try the Windows 7 driver from here. Realtek
If it doesn't work, try using the Vista driver, you may have to run it in compatibility mode. http://www.sevenforums.com/tutorials/316-compatibility-mode.html
I tried this before. did not work, but do you think it will work since i used the sweeper?
And which vista driver do you mean? the Realtek or the Asus?
I allready tried the asus driver in compatibility mode.
And what should i do if a driver does'nt work should i use the sweeper again? can this be a source to that the 'new' driver does'nt work?
Asus m70sr
Dolby Home Theater
17" TFT
Have you tried setting the Realtek High Definition Audio device to be the default for your headset?
INTEL/D975XBX2
1280 x 1024
Rocketfish 700 W
DSL
IE 11
ATI HDMI Audio
What do you mean?
As you can see on the picture i have the Realtek High Definition Audio Speakers as Standard.
And the relatek HD drivers did not help...
Asus m70sr
Dolby Home Theater
17" TFT
I just went into the device manager and i uninstalled everything under sound and rebooted, then i tried to install the relatek HD drivers again but windows automatically installed the same as i installed just before...
can this be the problem?
Asus m70sr
Dolby Home Theater
17" TFT
Don't set the speakers as your default device, try the one below (in your snapshot), or the ATI
INTEL/D975XBX2
1280 x 1024
Rocketfish 700 W
DSL
IE 11
ATI HDMI Audio
Windows 7 Ultimate 32 Bit, Windows Developer ...Intel Pentium Dual CPU E2180@2GHzNVIDIA GeForce 7200 GS
Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
Elitegroup 671T-M3
AOC TFT1560 15" LCD Monitor
1024x768
Logitech USB Keyboard
Tried this, did'nt work. i also 'tested' all of the options, but no one worked...
You can take a look at these very recent threads that discuss relevant sound issues with your case. You might see some important info from in there. Good Luck.
http://www.sevenforums.com/sound-audio/162058-speakers-not-working.html
http://www.sevenforums.com/sound-audio/161979-no-sound-speakers-onboard-audio.html
Looked trough and no one has the same problem...
My speakers work with the startup sound... so i know that they are not broken.
Asus m70sr
Dolby Home Theater
17" TFT
I just saw this!!!
with nothing attached to the 3 outputs one of them is still active :O
i usually use the middle (the black one) to connect my headphones.
when i look at the computer it says S/PDIF on the one that is active.
Why is this exit avtice all the time?
It must be the problem...
Asus m70sr
Dolby Home Theater
17" TFT
BUMP!
Can it be that i have the wrong drivers? or is it something wrong with the output? something electrical? What do you think?
Asus m70sr
Dolby Home Theater
17" TFT
