Windows 7: I have a Sigmatel audio onboard no sound!
12 Jul 2009   #1
sktigerjs
Window 7
I have a Dell XPS 410 with Sigmatel onboard soundcard and I installed the newest drivers that Driver Detective found for me which was IntelĀ® Desktop Board DG33TLĀ Audio: IDT* 92XX Driver
But I still have no sound working could somebody please help me to get the sound to work on my computer!!
12 Jul 2009   #2
nate42nd
Windows 7 Professional x64
Was the sound working before the new driver? If it was, I would go into the "device manager" and find the device, go to the driver tab and "roll back driver" this should at least get it working again then try to find out why the new driver will not work.
You may also try different speakers, headphones, ect to see if you have a bad cable or connection somewhere.
You may also go into the BIOS and see if the onboard sound is enabled if you have the option. Maybe someone gained access and disabled it.
Hopefully something here works.
12 Jul 2009   #3
sktigerjs
Window 7
No the sound never worked since I did a clean install of the 64 bit windows 7.
I have tried other speakers and head phones and none of them work. And my bios doesn't have a option to enable onboard sound :/
It's so frustrating because the sound is the only thing that's not working rawr!!
And I tried reading other sigmatel posts and none of them really helped
Please help me!
12 Jul 2009   #4
nate42nd
I assume you have read this from the site but here it is.
Quote:
No Sound Output to Speakers or Headphones
No sound output can be caused by several problems. The following suggestions may resolve the problem of no audio output:
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
And one more in case you are running 64 bit. (you may want to fill out the system specs ASAP.
Quote:
Audio Driver Installation Issue with Windows XP 64-Bit Edition
Audio drivers may fail to install in Windows XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error".
Microsoft's Update for Windows XP x64 Edition (KB901105)* fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
12 Jul 2009   #5
sktigerjs
Window 7
Hey thanks for the fast responds, but I figured it out, I switched the port that the speakers were going into, before in xp it worked fine in the black hole but I stuck it into another hole the green colored one and now the sound is working fine, thank you!
12 Jul 2009   #6
nate42nd
I'm glad you figured it out. Have a great day! and welcome to the forum.
12 Jul 2009   #7
zigzag3143
Win 8 Release candidate 8400
dell audio
Quote   Quote: Originally Posted by sktigerjs View Post
I also have a dell and installed the same driver and it didn't owrk for me either. niether did the one from dell. the only one that did work was the MS
hope this helps. there is also a whole thread for the same problem.
Ken
12 Jul 2009   #8
stormy13
Microsoft MVP
Win 7 Ultimate x64
Not sure why it was working in XP, only thing I can see is if it was set to 4.1 or 5.1 in the speaker settings; but the green jack has been the default color for the main/front speaker out for a long time.
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
Onboard Audio - no sound
After discovering that my beloved HT Omega Claro Plus soundcard cannot be installed on my new mb due to the lack of PCI slots, I decided to go with the onboard until I get a new card. I enabled onboard audio in the BIOS, downloaded and installed the latest drivers, went to Control Panel >...
No Sound from Speakers with Onboard Audio
I recently put together a new system with a fresh installation of Windows 7 64 bit. I cannot get sound to come from my speakers no matter what I have tried. I have trolled through all the forums I could find on the subject, and tried every possible solution, to no avail. I am hoping I simply...
No sound with onboard audio
Using Windows 7 64 bit. Have ASUS M4A79XTD board with onboard audio. Everything has been running great. There were no changes or upgrades done yesterday. There was a power failure at my house for a second and when it booted up it asked do you want to start up as usual or in safe mode etc. Ever...
Onboard audio and how to get 5.1/7.1 sound via HDMI
I'd figure I've got some time to make a new thread here for members of SevenForums who may have experienced some difficulty getting sound out of their computer via HDMI Locate the SPDIF connector on your motherboard using a 2 pin spdif cable PIN assignment # 1 Power 2 No pin 3 SPDIF...
Sigmatel Stac92XX C-Major HD Audio Driver Sound Problem
Hi I have A Dell XPS 420 with a Sigmatel Stac92XX C-Major HD Audio Driver and I was running Windows Vista X64 SP1 and everything was working fine. I just recently installed Windows 7 RT Build 7100 and the Generic High Definition Audio Device Driver Installed and all types of media play, but it's...
