IDT HD sound only sound on left!!
  1. Posts : 4
    I am using HP Pavilion dv6 Notebook PC and when i am using headset. It only comes out in the left (using IDT HD sound driver) i dont know what to do it`s kinda annoying plzz help!!??
  2. Posts : 4
    I mean when i play ect: music, games and movies
  3. Posts : 81
    win7 home premium-64bit-SP1-IE9RTM
    Welcome to the forum mikkeXD
    Open the “Show hidden icons” in the taskbar and locate the IDT icon then click on Open Audio Control Panel and a windows pop-up like mine
    Then you can adjust all the settings to your choice.
    Good luck
    Attached Thumbnails Attached Thumbnails IDT HD sound only sound on left!!-idt.jpg
  4. Posts : 4
    I tried that first and it didnt work
  5. Posts : 81
    Maybe there is something with your headset.
    Did you try it on a radio or other devices?
  6. Posts : 4
    It's not that either i checked it
  7. Posts : 81
    mikkeXD
    Try this one
    Open the IDT HD Interface then select PLAYBACK then INDEPENDENT DUAL HEADPHONES and finally select SETUP after that try to adjust the speakers balance like in this screenshot.
    maybe that will solve your problem.
