IDT HD sound only sound on left!!
mikkeXD
11:53 PM
I am using HP Pavilion dv6 Notebook PC and when i am using headset. It only comes out in the left (using IDT HD sound driver) i dont know what to do it`s kinda annoying plzz help!!??:sarc:
I mean when i play ect: music, games and movies
Welcome to the forum mikkeXD
Open the “Show hidden icons” in the taskbar and locate the IDT icon then click on Open Audio Control Panel and a windows pop-up like mine
Then you can adjust all the settings to your choice.
Good luck
win7 home premium-64bit-SP1-IE9RTMIntel core2 duo - T6600 2.2GHZ4.00GbATI Mobility Radeon HD 4530
HP pavilion DV6-Laptop
4.00Gb
IDT audio Monitor
32Bpp,1366x768
Western Digital 500Gb
Fast DSL
I tried that first and it didnt work :cry:
Maybe there is something with your headset.
Did you try it on a radio or other devices?
4.00Gb
IDT audio Monitor
32Bpp,1366x768
Fast DSL
It's not that either i checked it
mikkeXD
Try this one
Open the IDT HD Interface then select PLAYBACK then INDEPENDENT DUAL HEADPHONES and finally select SETUP after that try to adjust the speakers balance like in this screenshot.
maybe that will solve your problem.
4.00Gb
IDT audio Monitor
32Bpp,1366x768
Fast DSL
