Was there ever a solution to the "No audio output device is installed"
gregory2590
1:50 PM
I've been going on for a month without sound now. Earlier, it used to be a few times a week with sound. Stupid HP laptop.
Windows 7 Enterprise SP1 32bit
Windows 7 Ultimate x86DualCore AMD Athlon 64 X2, 2600 MHz 5200+Samsung 2GB DDR2Onboard NVIDIA GeForce 6150SE nForce 430
HP m8000n
Asus M2N68-LA (Narra)
Samsung 2GB DDR2
Onboard nVIDIA nForce 6100-430 (MCP61P)
Westinghouse 19" LED
1280x1024
SATA II Seagate Barracuda 500GB
USB II WD Elements 500GB
USB II WD My Book 1TB
USB II WD My Book 2TB
Stock (HP)
Stock (HP)
Logitech Classic KB 200
Standard HP opticle USB mouse
I can't install drivers when the laptop doesn't detect the sound card. Besides, when the sound actually works, installing new drivers doesn't stop the inevitable. I've tried this before.
It's just the other way around (especially with on-board "cards") The computer wouldn't see the device until it has appropriate drivers.But when you say you tried that already...nvm
HP m8000n
Samsung 2GB DDR2
1280x1024
Stock (HP)
Stock (HP)
check audio is enabled in bios
(or have you got a separate sound card for laptop - what make is it? in which case you should normally disable onboard sound)
if device shows in device manager
In device manager 'disable' the audio device driver with yellow exclamation - then re-enable it. It might kick in.
Also go into audio device > driver > update driver > 'search auto for updated driver'
See if that forces a correct install
WIN7 Ultimate 64bitAMD FX8150/Trinity A10-5700G-Skill 2400 x2 @ 1866 (both pc's)Sapphire (factory OC version) AMD 7770
D.I.Y.
WIN7 Ultimate 64bit
Asus Sabertooth v.1 /Asus F2A85-M Pro
onboard
T260 Samsung
Western Digital Sata 2TB/1TB Caviar Blacks
Buffalo 1TB usb (excellent drive)
Be-Quiet 700W E-9/Be-Quiet 550W E-9(E-9 = built by FSP)
Antec P183/Antec P180mini
x2 Xigmatek SXHH7-U01 + C-Master R4-EXBB-20PK-R0 120mm Fans
Cherry
MS Explorer 3.0
LG Blu ray combo
Pioneer 207D/208 Blu ray burners
How do I go about checking it in the bios? Also, the sound category doesn't show up at all in the device manager.
EDIT: found out how. but my bios didn't say a thing about sound
It might mention connexant or realtek in the bios
Additionally it might be hidden in an advanced menu that requires a special combination of keys to be pressed to reveal
can you fill out your system specs please
try this - easier than me posting it No Sound from the Speakers in Windows 7 - HP Customer Care (United States - English)
Try downloading the Win 7 High Definition drivers direct from realtek site (but can't be certain it's right guess, cos don't know your model of computer yet!)
D.I.Y.
WIN7 Ultimate 64bit
onboard
T260 Samsung
Cherry
MS Explorer 3.0
LG Blu ray combo
OS Version: Microsoft Windows 7 Enterprise , 32 bit
Processor: AMD Turion(tm) 64 X2 TL-58, x64 Family 15 Model 104 Stepping 1
Processor Count: 2
RAM: 2050 mb
Graphics Card: NVIDIA GeForce 7150M / nForce 630M, 64 Mb
Hard Drives: C: Total - 152617 MB, Free - 72084 MB;
Motherboard: Wistron, 30D6, 81.53,
The sound card is conexant. I'm 100% sure of it since that's the name I saw of it before this problem started happening. I've also tried the link you posted and it just told me "Hardware changes might not have been detected" And simply refreshing device manager to see the sound card doesn't help since the sound category doesn't even show up.
Processor Count: 2
RAM: 2050 mb
Anywhere near your model ? What is exact model number - am I in right country?
HP Pavilion dv2700 Entertainment Notebook PC series specifications - HP Home & Home Office Products
Hewlett-Packard HP Pavilion dv2700 Notebook PC F.24
System Serial Number:
Enclosure Type: Notebook
Processor a Main Circuit Board b 1.90 gigahertz AMD Turion 64 X2
64 kilobyte primary memory cache
1024 kilobyte secondary memory cache
64-bit ready
Conexant SmartAudio 221 3D Sound Blaster Pro compatible sound 16 bit integrated
Multi-core (2 total)
Not hyper-threaded
Board: Wistron 30D6 81.53
Bus Clock: 200 megahertz
BIOS: Hewlett-Packard F.24 04/24/2008
Drives Memory Modules c,d 160.04 Gigabytes Usable Hard Drive Capacity
There only appears to be an HP Vista driver - try installing it
If it won't run try installing it under 'compatability' mode
http://download.cnet.com/Conexant-High-Definition-SmartAudio-221/3000-2110_4-177475.html
D.I.Y.
WIN7 Ultimate 64bit
onboard
T260 Samsung
Cherry
MS Explorer 3.0
LG Blu ray combo
I don't remember where to check for the others but, my laptop is a dv2610(usa)
D.I.Y.
WIN7 Ultimate 64bit
onboard
T260 Samsung
Cherry
MS Explorer 3.0
LG Blu ray combo
