Windows 7: Is it possible to direct audio output to input (mic)
13 May 2011   #1
windows 7
I am looking for way to redirect audio from output (speakers) to input (mic) so that windows would think it's microphone. Actually I want to to be able to send sound to 2 devices at once 1 would be speakers so I can hears the sound and other device would be microphone so software that works with mic can hear that sound at once.
For example:
By redirecting audio output to microphone I would be able to stream sound trough msn/skype.
I heard it's easy with linux, but what about windows?
Edit I found Control Panel > Sound > Recording Enabling stereo mix does what I am looking for, but thing is that when my speakers sound volume is set to 50% then recording's sound volume will be 50% too. Is it possible listen sound at 50% but have a recording with 100% like set set sereo mix volume to 200%?
Or is there any tool to grab audio by process? like redirect everything from vlc to mic.
13 May 2011   #2
Win 8 Release candidate 8400
Quote   Quote: Originally Posted by LoveW7 View Post
For example:
Happy to help is you give us your system specs so we know what hardware you have. Especially your sound card/chipset
13 May 2011   #3
windows 7
Realtek High Definition Audio driver version 6.0.1.6278.
Quote:
Panel > Sound > Recording >> enabling stereo mix
I also found that this makes my real sound echo. I mean when I have this enabled under recording everything I hear gets repeated after 0.1 sec or so.
Edit I found that i can disable it from volume mixer.
13 May 2011   #4
While knowing the driver is a help, there are hundreds of devices that use that driver. We need the sound card (or chipset) ID so we can tell if it can do it.
btw it is call mixing and about half of the cards out there can do that.
13 May 2011   #5
windows 7
where I can get that? I done get it (better information) from device manager.
13 May 2011   #6
Win 7 Ultimate x64
Etobicoke, Ontario
If you can't get the stereo mix to work properly (have to wait on someone that uses it for how to configure it correctly), you can do it with a stereo splitter like this,
Newegg.com - Belkin 6" 6IN Y SPLITTER MINI STEREO Model F8V234
and a short male-male extension cable,
Newegg.com - BYTECC 6 ft. 3.5mm Stereo Speaker Cable - Male To Male, Black Jacket Model SPC-6MM
Plug the splitter into the speaker jack and the speakers and one end of the cable into the splitter, with the other end into the mic/line in jack. Then set the mic/line in jack (assuming they are both on the same jack) to line in and record that way.
15 May 2011   #7
windows 7
that's hardware way, but is there any software that does it in software layer? Like something to simulate mic device.
05 Jul 2012   #8
I have just found one in windows.
Here's what I did:
Went into the sound manager in windows,
(Control Panel>Hardware and Sound>Sound)
Clicked on the "Recording" tab,
Right clicked on one of the list items and then clicked "Show Disabled Devices"
A few (depending on system) more item showed up, one of them "Stereo Mix" (or something similar to that, i assume it may say 5.1 or some other "Mix"), right clicked and went "Enable".
Then in whatever program you are using (Eg. Skype) you would set the input device to the "Stereo Mix", rather than your mic input.
I don't think that Skype or whatever you are using will be able to hear the mic at the same time though, however, you could set the mic to play though the speakers and "get caught" by the output as well.
Hope this helps.
 Is it possible to direct audio output to input (mic) problems?
Similar help and support threads for: Is it possible to direct audio output to input (mic)
Direct password input on log-on screen Customization
pc's output going in mic input Sound & Audio
how to selet input from Direct show Graphic Cards
input to output Sound & Audio
Realtek HD Audio, PC input yes/ HDTV input no Sound & Audio
