mic recording volume very low
  1. Posts : 15
    Win7 64bit Ultimate
    hi all,
    im having trouble with my headphones mic which from some reason recording volume is very low .
    so low that in game (by using TS [teamspeak]) when other people have the game sound , they can bearly hear me.
    i set my mic to 100 volume and the boost to +30db but thing stay the same.
    when i test the mic with recorder the bar even dont rised a little bit .
    ohh , and by the way , in case anyone thought the problem isnt in the mic which is new due to the fact that after this problem happend at the last microsoft headphones i had, i bought new one (forgot the model).
    any help here ?
    im using windows 7
    64bit premium
  2. Posts : 2,393
    Microsoft Windows 7 Ultimate: x64 (SP1)
    Hello fibola & Welcome to 7Forums!
    What headphones to you have?
    If it's Logitech etc. there might be some type of driver or an utility. Look for their website, or either way, you might have a DVD with driver.
    See if Windows have been putting up the right input for your microphone. Maybe the default input is broken, who knows!
    Also make sure the software you're communicating with is functional.
    Good luck
    Best Regards,
    FredeGail
  3. Posts : 15
    Win7 64bit Ultimate
    its a creative (headphone with mic on it).
    i have 2 input for the mic . one at the front of my pc tower and second on the back.
    both record the same.
    when i plugin the mic line i get pop up windows which prompt on a mic connection.
    any more ideas ?
    i will look at creative web site.
  4. Posts : 2,393
    Try here
    Creative Worldwide Support
    Best Regards,
    FredeGail
  5. Posts : 15
    Win7 64bit Ultimate
    thanx
