No Sound From Front Headphone Jack
When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500.
The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't. Even when I had my headphones plugged it they werent getting picked up on Playback devices.
A friend of mine told me to just delete the driver, and let windows download its own sound driver (it didn't do it when I installed windows for some reason). So, I rebooted after uninstalling the SoundMax driver and Windows automatically downloaded and installed the "High Definition Audio Device" driver.
Now the audio icon in the windows tray has a red cross on and says "No speakers or headphones are plugged in" I plugged my headphones in on the fron headphone jack and its not picking them up.
I click the icon and let it troubleshoot headphones. I get the following message "The peripheral does not appear to be plugged in. Check the connection. Proceed to next step to finish." I unplug them and plug them back in, click next, and it just says the issue is not fixed.
I have taken the side panel off and check the connections and all wires are connected.
dxdiag is showing as no sound card present. Results are below:
Am I downloading the wrong driver? What driver should I get?Code:------------------ System Information ------------------ Time of this report: 5/28/2011, 10:50:31 Machine name: DAMONANDHANNAH Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110408-1631) Language: English (Regional Setting: English) System Manufacturer: Dell Inc. System Model: Precision WorkStation T7500 BIOS: Phoenix ROM BIOS PLUS Version 1.10 A07 Processor: Intel(R) Xeon(R) CPU X5660 @ 2.80GHz (12 CPUs), ~2.8GHz Memory: 49152MB RAM Available OS Memory: 49150MB RAM Page File: 3850MB used, 94446MB available Windows Dir: C:\Windows DirectX Version: DirectX 11 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled DxDiag Version: 6.01.7601.17514 32bit Unicode ------------ DxDiag Notes ------------ Display Tab 1: No problems found. Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer. Input Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA Quadro NVS 295 Manufacturer: NVIDIA Chip type: Quadro NVS 295 DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_06FD&SUBSYS_062E10DE&REV_A1 Display Memory: 3815 MB Dedicated Memory: 231 MB Shared Memory: 3583 MB Current Mode: 1680 x 1050 (32 bit) (59Hz) Monitor Name: ViewSonic VA2216w-4 Monitor Model: VA2216w SERIE Monitor Id: VSC2920 Native Mode: 1680 x 1050(p) (59.954Hz) Output Type: Displayport External Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um Driver File Version: 8.17.0012.7071 (English) Driver Version: 8.17.12.7071 DDI Version: 10 Driver Model: WDDM 1.1 Driver Attributes: Final Retail Driver Date/Size: 4/28/2011 06:39:04, 12936808 bytes WHQL Logo'd: Yes WHQL Date Stamp: Device Identifier: {D7B71E3E-45BD-11CF-F168-22261FC2C535} Vendor ID: 0x10DE Device ID: 0x06FD SubSys ID: 0x062E10DE Revision ID: 0x00A1 Driver Strong Name: oem3.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section012:8.17.12.7071:pci\ven_10de&dev_06fd Rank Of Driver: 00E62001 Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= D3D9 Overlay: Supported DXVA-HD: Supported DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled ------------- Sound Devices ------------- Description: Default Sound Playback: No Default Voice Playback: No Hardware ID: Manufacturer ID: Product ID: Type: Driver Name: Driver Version: Driver Attributes: WHQL Logo'd: Date and Size: Other Files: Driver Provider: HW Accel Level: Emulation Only Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No --------------------- Sound Capture Devices --------------------- ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Poll w/ Interrupt: No ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x8086, 0x3A34 | Matching Device ID: usb\root_hub | Service: usbhub ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + HID Keyboard Device | Vendor/Product ID: 0x413C, 0x2106 | Matching Device ID: hid_device_system_keyboard | Service: kbdhid | + Terminal Server Keyboard Driver | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | + HID-compliant mouse | Vendor/Product ID: 0x046D, 0xC063 | Matching Device ID: hid_device_system_mouse | Service: mouhid | + Terminal Server Mouse Driver | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 31.2 GB Total Space: 152.5 GB File System: NTFS Model: ATA WDC WD1600HLFS-7 SCSI Disk Device Drive: E: Free Space: 129.5 GB Total Space: 152.6 GB File System: NTFS Model: ATA WDC WD1600HLFS-7 SCSI Disk Device Drive: G: Free Space: 727.9 GB Total Space: 953.2 GB File System: NTFS Model: WD My Book 1110 USB Device Drive: D: Model: PLDS DVD+-RW DH-16ABS ATA Device Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes Drive: F: Model: WD Virtual CD 1110 USB Device Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes Drive: H: Model: DTSoftBusCd00 Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes -------------- System Devices -------------- Name: Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A Device ID: PCI\VEN_8086&DEV_3A4A&SUBSYS_026D1028&REV_00\3&172E68DD&0&E5 Driver: n/a Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36 Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_026D1028&REV_00\3&172E68DD&0&EA Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423 Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_006D0028&REV_22\3&172E68DD&0&A2 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_026D1028&REV_22\3&172E68DD&0&18 Driver: n/a Name: NVIDIA Quadro NVS 295 Device ID: PCI\VEN_10DE&DEV_06FD&SUBSYS_062E10DE&REV_A1\4&17EC323&0&0038 Driver: n/a Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40 Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_026D1028&REV_00\3&172E68DD&0&E0 Driver: n/a Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35 Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_026D1028&REV_00\3&172E68DD&0&E9 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423 Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_22\3&2FC90B2B&0&A2 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408 Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_026D1028&REV_22\3&172E68DD&0&08 Driver: n/a Name: Texas Instruments 1394 OHCI Compliant Host Controller Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_026D1028&REV_00\4&233C1052&0&50F0 Driver: n/a Name: High Definition Audio Controller Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_026D1028&REV_00\3&172E68DD&0&D8 Driver: n/a Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34 Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_026D1028&REV_00\3&172E68DD&0&E8 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422 Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_006D0028&REV_22\3&172E68DD&0&A1 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3406 Device ID: PCI\VEN_8086&DEV_3406&SUBSYS_026D1028&REV_22\3&172E68DD&0&00 Driver: n/a Name: Dell SAS 6/iR Integrated Workstation Controller Device ID: PCI\VEN_1000&DEV_0058&SUBSYS_021D1028&REV_08\4&3DF0BE&0&00E0 Driver: n/a Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_026D1028&REV_00\3&172E68DD&0&D7 Driver: n/a Name: Intel(R) ICH10 Family SMBus Controller - 3A30 Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_026D1028&REV_00\3&172E68DD&0&FB Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422 Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_22\3&2FC90B2B&0&A1 Driver: n/a Name: Intel(R) 82801 PCI Bridge - 244E Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_026D1028&REV_90\3&172E68DD&0&F0 Driver: n/a Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_026D1028&REV_00\3&172E68DD&0&EF Driver: n/a Name: Intel(R) ICH10 Family 6 Port SATA AHCI Controller - 3A22 Device ID: PCI\VEN_8086&DEV_3A22&SUBSYS_026D1028&REV_00\3&172E68DD&0&FA Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 9 - 3410 Device ID: PCI\VEN_8086&DEV_3410&SUBSYS_026D1028&REV_22\3&2FC90B2B&0&48 Driver: n/a Name: Intel(R) PRO/1000 MT Server Adapter Device ID: PCI\VEN_8086&DEV_1026&SUBSYS_10018086&REV_04\5&A463B67&0&000008 Driver: n/a Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39 Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_026D1028&REV_00\3&172E68DD&0&D2 Driver: n/a Name: Intel(R) ICH10R LPC Interface Controller - 3A16 Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_026D1028&REV_00\3&172E68DD&0&F8 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_026D1028&REV_22\3&2FC90B2B&0&38 Driver: n/a Name: Broadcom NetXtreme 57xx Gigabit Controller Device ID: PCI\VEN_14E4&DEV_1681&SUBSYS_026D1028&REV_10\4&351402F6&0&00E5 Driver: n/a Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38 Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_026D1028&REV_00\3&172E68DD&0&D1 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_006D0028&REV_22\3&172E68DD&0&A0 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_026D1028&REV_22\3&172E68DD&0&38 Driver: n/a Name: PCI standard PCI-to-PCI bridge Device ID: PCI\VEN_12D8&DEV_E130&SUBSYS_00000000&REV_04\4&2F86DE32&0&0008 Driver: n/a Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37 Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_026D1028&REV_00\3&172E68DD&0&D0 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_22\3&2FC90B2B&0&A0 Driver: n/a Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_026D1028&REV_22\3&2FC90B2B&0&18 Driver: n/a Name: NVIDIA Quadro NVS 295 Device ID: PCI\VEN_10DE&DEV_06FD&SUBSYS_062E10DE&REV_A1\4&26E0BFED&0&0018 Driver: n/a ------------------ DirectShow Filters ------------------ DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514 WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514 WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514 MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385 Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385 WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514 WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514 Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385 Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385 WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109 Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109 WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109 WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109 WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109 WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3508.1109 WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3508.1109 DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514 Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17514 WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514 MainConcept AAC Decoder,0x00400000,1,1,, Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514 AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17514 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17514 SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528 Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000 "MainConcept (Adobe2) AAC Decoder",0x00600000,1,1,ad2daac.ax", "MainConcept (Adobe2) MPEG Splitter",0x005fffff,1,2,ad2mcspmpeg.ax", "MainConcept (Adobe2) MPEG Audio Decoder",0x005fffff,1,1,ad2mcdsmpeg.ax", "MainConcept (Adobe2) MPEG Video Decoder",0x005fffff,1,1,ad2mcdsmpeg.ax", "MainConcept (Adobe2) MPEG Encoder",0x00200000,2,1,ad2mcesmpeg.ax", "MainConcept (Adobe2) MPEG Video Encoder",0x00200000,1,1,ad2mcevmpeg.ax", "MainConcept (Adobe2) MPEG Audio Encoder",0x00200000,1,1,ad2mceampeg.ax", "MainConcept (Adobe2) MPEG Multiplexer",0x00200000,1,1,ad2mcmuxmpeg.ax", AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528 MainConcept MP4 Demultiplexer,0x00400000,1,2,, StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528 MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514 MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17514 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514 VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528 Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514 SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528 Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17514 DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17514 MainConcept (Consumer) AVC/H.264 Video Decoder,0x00400000,1,2,, Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514 ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17514 Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17514 MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528 Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17514 Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17514 Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17514 File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3508.1109 VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514 WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514 File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514 "MainConcept (Adobe2) AAC Encoder",0x00100000,1,1,ad2eaac.ax", iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514 iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514 DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17514 Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17514 AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17514 RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll, Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514 WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528 DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514 SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514 Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514 MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514 Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514 StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528 Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514 Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17514 AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17514 AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17514 Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514 MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514 Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17514 File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17514 TechSmith File Source,0x00400000,0,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith SWF Writer,0x00200000,2,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith WMFSDK Writer,0x00200000,1,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Simple PIP,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 ImageSource,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TitleSource,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Time Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Splitter Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Frame Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Perf Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith ZoomPIP Filter,0x00200000,2,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith PushVMR Source,0x00200000,0,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith PushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.00.0000.1426 TechSmith PushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.00.0000.1426 TechSmith SimplePushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Wave Dest,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Overlay,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Wave Buffer,0x00200000,1,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith ForceColor 8,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith ForceColor 555,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith ForceColor 565,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith ForceColor 24,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith ForceColor 32,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Force Color32A,0x00200000,0,0,CamtasiaFilters.dll,7.00.0000.1426 SSFileWriter,0x00200000,1,0,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Frame Rate Tuner,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Camera Adjust,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 Techsmith Quicktime MOV Source,0x00600000,0,2,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Sound Effects Filter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Flv Key Frame Setter,0x00200000,1,1,CamtasiaFilters.dll,7.00.0000.1426 TechSmith Floating Point Wave Filter,0x00800000,1,1,CamtasiaFilters.dll,7.00.0000.1426 Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000 StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528 AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514 Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17514 File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17514 File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17514 LAME Audio Encoder,0x00100000,2,1,lame_dshow.ax,1.00.0054.50801 Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514 Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514 BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17514 MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17514 "MainConcept (Adobe2) H.264/AVC Decoder",0x00600000,1,1,ad2dsh264.ax", "MainConcept (Adobe2) H.264 Encoder",0x00200000,2,1,ad2esh264.ax", "MainConcept (Adobe2) H.264/AVC Video Encoder",0x00200000,1,1,ad2evh264.ax", iZotope Vocal Enhancement,0x00200000,1,1,iZotope_VocalEnhancement.dll,1.00.0000.0024 iZotope Consumer Restoration,0x00200000,1,1,iZotope_ConsumerRestoration.dll,1.00.0000.0024 WDM Streaming Tee/Splitter Devices: Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514 Video Compressors: WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385 WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385 MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385 DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514 "MainConcept (Adobe2) H.264/AVC Video Encoder",0x00200000,1,1,ad2evh264.ax", "MainConcept (Adobe2) MPEG Video Encoder",0x00200000,1,1,ad2mcevmpeg.ax", MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17514 Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514 Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514 Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514 Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514 Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514 TechSmith Screen Capture Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514 VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.06.7601.17514 VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.06.7601.17514 Audio Compressors: WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385 WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385 "MainConcept (Adobe2) MPEG Audio Encoder",0x00200000,1,1,ad2mceampeg.ax", IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514 PCM,0x00200000,1,1,quartz.dll,6.06.7601.17514 Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17514 GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17514 Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7601.17514 CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514 CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17514 MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17514 PBDA CP Filters: PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528 PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528 PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528 Midi Renderers: Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17514 Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17514 BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514 Multi-Instance Capable VBI Codecs: VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514 BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17514 MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514 BDA CP/CA Filters: Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17528 Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17528 PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17528 XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17528 WDM Streaming Communication Transforms: Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514 Audio Renderers: Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17514 Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17514 --------------- EVR Power Information --------------- Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality) Quality Flags: 2576 Enabled: Force throttling Allow half deinterlace Allow scaling Decode Power Usage: 100 Balanced Flags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 50 PowerFlags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 0
Any help is much appreciated :)
