No Audio Output via Front and Rear Jacks
flaergr
2:03 AM
Hey guys,
I installed the Hyper 212+ this weekend, but after installation, the audio stopped working. Thinking that this was a hardware issue, I went back and replugged some of the cables back into the mobo to make sure they were securely in there. No luck.
My setup (other specs in profile):
- Phenom x4 955
- Radeon 5850
- ASRock 870 Extreme3
Sound appears to work (green bars move, Windows doesn't detect any problems), but there's no output. Here's what the Sound control panel looks like:
(Note that I do indeed have speakers/headphones plugged in.)
I also went into the Realtek HD Audio Manager to see what's going on and it lists only Digital Output. None of the analog jacks appear to be active in the Manager window, unless I disable front panel jack audio detection. Here's what it looks like with front panel detection enabled:
And with front detection disabled:
I've done a couple of things so far:
- Tried headphones and speakers in front and rear audio jacks.
- Even tried microphone in front mic-in jack - didn't work. A USB (connected to front panel) mic did work, however.
- Restored BIOS to factory defaults.
- Disabled/re-enabled onboard audio in BIOS.
- Installed/uninstalled/reinstalled audio and video drivers.
I've also messed around with the Realtek HD Audio Manager itself:
- I disabled front panel jack audio detection. This added two additional in/ouputs: Speakers and FrontMic. Neither work.
- Changed default device to speakers. Nada.
- Tried enabling "Make front and rear output devices playback two different audio streams simultaneously."
I even looked at the registry after checking out the Changing Jacks stickied thread in this forum, but not all the jacks are listed (?):
So anyway, I have no clue what the problem is other than maybe it's outputting the sound digitally via SDPIF for some reason and I can't figure out how to get Windows/Realtek to detect the analog output jacks instead.
Help anyone?
Windows 7 Home Premium 64 bitAMD Phenom II X4 955G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin ...PowerColor AX5850 Radeon HD 5850 1GB
ASRock 870 Extreme3
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3
onboard
ASUS VH236H Black 23" Full HD Widescreen LCD Monitor
SAMSUNG Spinpoint F3 1TB 7200 RPM SATA 3.0Gb/s
Rosewill Challenger
COOLER MASTER Hyper 212 Plus
flaergr, welcome to the Seven Forums.
Might help if you set the Speakers as the default device instead of the digital one. Unless you're specifically using the optical/digital connections on the back, both the regular and front panel jacks are analogue.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Yeah, I've tried setting the Speakers to the default device (which only became available after disabling the front panel detection), but there was no change - still no audio.
My hypothesis is that Windows is only outputting digitally to SPDIF and I can't force it (for whatever reason) to output to the analog jacks.
ASRock 870 Extreme3
onboard
Rosewill Challenger
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Hey I have this problem more or less, Im very frustrated with it and would greatly appreciate it if anyone knew a solution to it?
Windows 7 Home Premium 64 bit8 gb RAM, though only 6 show up (?)Nvidia GTX 570
SX58
Nvidia GTX 570
Shuttle mini pc
