Windows 7: Microphone volume too low
18 Jul 2009   #11
01steven
Quote   Quote: Originally Posted by darkassain View Post
im wondering if a sound driver install would make this go away
look at both and look at which one has this as the Jack info...
Attachment 18742
that is your internal mic
you not being able to boost your mic (is this a stereo or mono mic?) should be more than enough for me to think that its a driver problem...
also have that mic as the default communication device...
I have attached screenshots of the properties of both mics (not sure if the images will automatically load in the message or not- apologies if they don't, I'm not that familiar with this forum).
Mic 1 is described as a digital jack, mic 2 is described as front panel 3.5mm jack.
I assume from that that mic 1 is my internal jack (I have plugged external mics into the 3.5mm jack at the front of my laptop before, which must be mic 2).
If this is the case, how do I go about testing the drivers?
I have been in device manager and under sound, video and game controllers there are 2 options- both called 'high definition audio device' but I don't think either of these are my internal mic. It seems there's an automatic driver software update which I ran anyhow on both of these and it says the drivers are up to date.
I've attached a screenshot of my device manager if this is of any use.
[IMG]file:///C:/Users/Steven/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Steven/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
Microphone volume too low-mic1.jpg   Microphone volume too low-mic2.jpg   Microphone volume too low-device-manager.jpg
19 Jul 2009   #12
01steven
I downloaded new drivers from the Dell website.
Now my mic settings look like this.
Have just been testing the mic and it is working on normal volume but then pretty much fades to zero for a few seconds, before coming back to normal.
Not sure if this is the same issue as before, presumably still a Windows 7 bug?
By the way, will users of the release candidate get updates to Windows 7, or do all the updates appear in the paid-for version?
19 Jul 2009   #13
darkassain
Quote   Quote: Originally Posted by 01steven View Post
have you boosted the mic at all? (get to the properties of the array mic click on levels and then slide the mic boost to +20...
also there might be settings in the enhancements page which you can try that might help you...
by updates do you mean standard 2nd tuesday of month kind of patches?
most likely no since its a different OS build (I mean the RTM)
im certain that after the GA date (october 22 i believe) the RC string will be deleted from MS so no more updates for the RC (although it can happen sonner than that) ..
19 Jul 2009   #14
Dwarf
Windows 8.1 Pro RTM x64
Have you checked the settings on this tab?
19 Jul 2009   #15
tadas
windows 7
Have you tried skype>tools>options>audio settings and untick automaticaly adjust microphone settings?
19 Jul 2009   #16
01steven
I don't have the mic boost option on the levels tab
19 Jul 2009   #17
01steven
Quote   Quote: Originally Posted by Dwarf View Post
Attachment 18977
mmm...tried this and still no joy unfortunately.
Mic is working- I don't think it's too low anymore- it's more about background noise/clarity and the whole fading in and out issue
20 Jul 2009   #18
01steven
Any other ideas anybody?!
20 Jul 2009   #19
Orbital Shark
Sorry Steven i'm frash out of ideas
As i said before I had the same issue with Skype & solved it by just disabling 1 of the microphones
Hopefully someone can help, you may just need to give them a bit of time to read the post
Jeff
20 Jul 2009   #20
stormy13
Microsoft MVP
Win 7 Ultimate x64
That and the mic boost option is on the Custom tab (or at least it alwys has been for me),
which is missing from all the screen shots that Steven has posted.
Just had a look at what is available for an audio driver for his laptop, and Dell has a 32 bit Vista driver for it (BTW you running 32 0r 64 bit?). That being said time for some of the Sigmatel experts to weigh in here.
Microphone volume meter for taskbar?
I am looking for a simple program that will allow me to monitor my microphone volume from my task bar. A meter or gauge of some sort would be perfect. I would also settle for an unobtrusive meter/gauge on my desktop. thank for your help :D
Software
Razer Kraken Microphone volume really low
I have a pretty good computer, and a pretty good headset (Razer Krakens 7.1) but when i speak it's really low, I've checked alot of forums and none of there solutions have worked, I use realtek and sound blaster, But still it's really Low if somebody has a fix please share because Im on the verge...
Microphone volume is agonizingly low
Every textbook way to fix the mic being low has failed for me. Can anyone help? It needs to be pretty much be in my mouth to be a decent volume. Microphone levels at max + boost? Tried it. Set the correct microphone port as default device? Tried it. Double check communications tab to...
Microphone volume reduced
Hello All, I did a fresh Windows 7 installation on a new hard disk drive on my laptop.I am using Dell Inspiron 1525 laptop.However, after installation the microphone seems to be behaving weirdly(volume has reduced).I see that the system is automatically adjusting the volume of the...
Microphone volume won't stay put
I want to lower my microphone volume from 100 to 50. When I do it, it will stick around for a little while (while I record something), but then it will jump back to 100 sometime after I'm done or even before I start. For some reason, the adjustment just won't be saved. I'm hitting OK to close the...
Does program for microphone volume exist?
Hope I am posting in the correct section, even though I don't use Windows 7 gadgets. I find them to be too distracting and I like a clean desktop. I searched this entire thread and did not find what I am looking for, maybe someone can help though. :cry: I would like a program that allows me...
