I have attached screenshots of the properties of both mics (not sure if the images will automatically load in the message or not- apologies if they don't, I'm not that familiar with this forum).
Mic 1 is described as a digital jack, mic 2 is described as front panel 3.5mm jack.
I assume from that that mic 1 is my internal jack (I have plugged external mics into the 3.5mm jack at the front of my laptop before, which must be mic 2).
If this is the case, how do I go about testing the drivers?
I have been in device manager and under sound, video and game controllers there are 2 options- both called 'high definition audio device' but I don't think either of these are my internal mic. It seems there's an automatic driver software update which I ran anyhow on both of these and it says the drivers are up to date.
I've attached a screenshot of my device manager if this is of any use.
[IMG]file:///C:/Users/Steven/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Steven/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
