Windows 7: Realtek HD Audio Manager not in Control Panel
14 Jul 2012   #41
Windows 7 x64
Solved but some presets missing
I uninstalled all audio/realtek drivers from device manger & add/remove programs, unfortunately also removed realtek PCIE card reader, now need to install that again. After reinstalling the drivers from the manufacturer's cd (alienware M14x), the Audio Manager came back.
But there were lot more presets on the Waves Tab before it disappeared, only left with 4 now (Gaming/Voice/Movies/Music). For an audio noob like me, the other presets would have been helpful
26 Jun 2015   #42
win 7
the problem is that beginning with r.2.67 of the realtek hd audio codec they added waves maxx audio
if you install r2.66 or early you will get the manager back
sadly most of the posters here had no clue what was going on
Search this Thread:
Advanced Search
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek Audio Control Panel wont open
Hello out there; first time on this forum, but first time I've hit a problem I can't seem to find a working solution for, so I hope someone can help. I've seen similar issues, and tried multiple solutions, but so far nothing has changed. I recently purchased a Dell XPS laptop running Windows7...
NO SOUND and my Realtek HD Audio will not open from the control panel
Windows 7 86. I have NO SOUND and my Realtek HD Audio will not open from the control panel. I have reinstalled the drivers and used system image to recover but it has not solved the problem. I have used this system image before and it work perfect. I think it is a hardware problem but how can I...
Get rid of Control Panel,Device Manager,etc.. in desktop right-click
Hey Actually what happened is I got some .ico files and some regdit file that guy who gave it just wrote to copy it and give merge and i now get Control Panel,Device Manager,etc.. in my desktop right-click background so i need to know how to delete those items from my context menu of desktop Please...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
