Solved Realtek HD Audio Manager not in Control Panel
MultiCat
5:44 AM
Birmingham
Hi everyone,
I've just installed the latest Realtek driver and the installation goes fine but Realtek HD Audio Manager won't appear in the Control Panel or the System Tray (however, when I go to customize the notification icons, Realtek HD Audio Manager appears as "Show icon and notifications").
I've tried reinstalling time and time again. Also, Device Manager shows 4 instances of "High Definition Audio Device" as well as Realtek High Definition Audio. I've tried uninstalling these and installing Realtek but Windows automatically installs them upon restart.
Anyone got any ideas?
Windows 7 Home Premium 64bitPentium(R) Dual-Core E5400 @ 2.70 GHz4096MBNVIDIA GeForce GT 220
Medion Akoya E4015
4096MB
18.5"
1366 x 768
Microsoft Windows 7 Ultimate: x64 (SP1)Intel® Core™ i5-2500K ProcessorKingston DDR3 HyperX 1600MHz 8GBASUS GTX 560 TI DirectCU II 900MHz
Brewed
ASUS P8Z68-V PRO
Realtek® ALC892 8-Channel High Definition Audio CODEC
ACER LCD P246HBD 1920x1080 (24") - Dell 1280x800
ACER LCD P246HBD ~ [1920X1080] - DELL ~ [1280x800]
500 GB WD Caviar SE116 7200rpm SATA2
Corsair 750W Power Supply
Coolermaster CM Scout
Zalman FS-C77 Fatal1ty CPU Cooler
Logitech G15
Coolermaster Sentinel Advanced
[↓ 10 MB/s DL] [↑ 1 MB/s UL]
- ROCCAT™ Kave – Solid 5.1 Surround Sound Gaming Headset
- Not overclocking
Medion Akoya E4015
4096MB
18.5"
1366 x 768
Hello MultiCat & Welcome to SevenForums!
Try following this fix (I've smashed up a #permalink for you):
Solved Realtek hd audio not showing up in control panel - Vista Forums
Best Regards,
FredeGail
Thanks FredeGail. However, the problem is Realtek HD Audio Manager isn't showing in the System Tray or in the Control Panel.
Have you been downloading the driver only, or the utility included?
Link for download: http://www.sevenforums.com/sound-audio/3756-latest-realtek-hd-audio-driver-version.html
Best Regards,
FredeGail
Brewed
ASUS P8Z68-V PRO
Logitech G15
- Not overclocking
Best Regards,
FredeGail
Best Regards,
FredeGail
I've been downloading the latest drivers (which include the Audio Manager) from the Realtek website.
Realtek
Medion Akoya E4015
4096MB
18.5"
1366 x 768
You may have another soundcard driver installed.
Look for it in Device Manager. My suggest is to uninstall the Realtek driver in Control Panel all normal, and then download Driver Sweeper, and clean the leftover files following your soundcard.
Best Regards,
FredeGail
Brewed
ASUS P8Z68-V PRO
Logitech G15
- Not overclocking
Best Regards,
FredeGail
I'm trying that now.
Just something I noticed when I was using Task Manager is that RAVCpl64.exe (Realtek HD Audio Manager) is a running process. Strikes me as a little odd...
Medion Akoya E4015
4096MB
18.5"
1366 x 768
Your RAVCpl64.exe should remove when uninstalling your driver. That's my guess.
And it'll probably be back when installing the driver back on :geek:
Best Regards,
FredeGail
Brewed
ASUS P8Z68-V PRO
Logitech G15
- Not overclocking
Best Regards,
FredeGail
Just tried using Driver Sweeper to remove the stray files and then install the drivers again and I'm still getting the same problem.
Medion Akoya E4015
4096MB
18.5"
1366 x 768
You may use Revo Uninstaller Freeware in advanced mode to delete all the leftover files during uninstallation .
After that you may try installing realtek again !
Self Assembled
LG Flatron E2040T
1600x900
Western Digital 1 TB
Seagate 500 GB
Corsair VS550
Cooler Master K380
Logitech MK260r
Logitech MK260r
PMPL Broadband
Windows Defender + MBAM
Dell Studio 15" Laptop
Realtek HD Audio Manager is not appearing in the Add or Remove Programs window so I can't do that.
Medion Akoya E4015
4096MB
18.5"
1366 x 768
Sager NP9170
Win 7 Pro x64 / Win 10 Pro
CLEVO P170EM
12 GB
Backlite
MSE, Malwarebytes Pro
DESKTOP: Custom-built.
OS: Win 10 Pro x64.
CASE: Rosewill R5.
MOTHERBOARD: Asus Z87-A.
GPU: Nvidia Geforce 650 TI.
PSU: Corsair TX750.
Medion Akoya E4015
4096MB
18.5"
1366 x 768
Self Assembled
LG Flatron E2040T
1600x900
Seagate 500 GB
Corsair VS550
Cooler Master K380
Logitech MK260r
Logitech MK260r
PMPL Broadband
Medion Akoya E4015
4096MB
18.5"
1366 x 768
Now the Realtek HD Audio drivers are showing up in Add or Remove Programs and in Revo Uninstaller. Could this have something to do with my recent upgrade to 64bit?
Medion Akoya E4015
4096MB
18.5"
1366 x 768
Probably. Windows 7's driver base is huge now so in most cases Device Manager is fully populated without any action on the user's part.
HP Pavilion Elite 495UK
Windows 7 Ultimate SP1 64-Bit
Intel Core i7 870 @ 2.93GHz
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
Logitech Wireless M180 mouse
2Mb
But could that explain why I'm not able to access the HD Audio Manager?
Medion Akoya E4015
4096MB
18.5"
1366 x 768
I'm not sure, but it's quite possible.
You might want to uninstall your HD drivers using Revo and ask it to carry out a deep scan of your registry to remove any remnants and leftovers from previous installations, but do make sure you check carefully what you're deleting and backup the registry before you start.
Having done that you can then install Realtek's latest drivers to see whether you get your Audio Manager back.
MSI 2A9C (CPU1)
HP2310i
460W
HP Elite
Air cooled
2Mb
I've done that and there's still no Audio Manager in the System Tray or the Control Panel.
Medion Akoya E4015
4096MB
18.5"
1366 x 768
