Win7 included 'Codecs'
Hi, how do I find what 'Codecs' are included in Home Prem 32bit OS?
Loads of information here: Codecs: frequently asked questions
Included in the link is this snippet:
If you need to see a list of the Windows Media Player components and codecs installed on your computer, do the following:
- On the Help menu, click About Windows Media Player.
If the Help menu is not visible, click Organize, point to Layout, and then select Show menu bar.- On the About Windows Media Player dialog box, click Technical Support Information.
Your web browser will open a page that includes information about the related binary files, codecs, filters, plug-ins, and services installed on your computer. A technical support person might be able to use this detailed information to help you troubleshoot problems on your computer.
In the control panel, put: Control Panel\All Control Panel Items\Performance Information and Tools\Advanced Tools, in the address bar. Select "View advanced system details in System Information. In there, hit the + by Components. Hit the + by Multimedia. There you can view your video or audio codecs.
You're very welcome. Pleased we could help you.
