Problem with SB X-fi Titanium Fatal1ty Pro series
dpproject
3:10 PM
I have a SB X-fi titanium Fatal1ty pro series, is a PCI express card.
Recently I've installed windows 7 64 bit in my computer, and I can instal drivers and applications. I have a 5.1 headphones with SPDIF input, it's the Sharkoon x-tactic 5.1
The problem is I can't activate the Dolby Digital Live codec to transform the sound in 5.1 and play with this sounds. When I try to select the check box for turn on the codec it keeps in disable and show a message, something like... Creative Audio Service donr run, please reinstall.
I've tried to uninstall and reinstall all applications and drivers, but it doesn't work. I dont know where is the *.exe of the creative audio service.
Can you help me?, please
Windows seven2xQuad-Core Intel Xeon 3.0GHz8,00 GBnVIDIA GeForce 8800 GT 512 MB
Windows seven
Mac Pro
8,00 GB
Sound Blaster X-fi Titanium Fatal1ty Pro Series
Apple Cinema Display 30" and Wacom CINTIQ 21UX
2560x1600 and 1600x1200
Apple Keyboard
Wacom Intuos3 and Logitech G9
dpproject, welcome to the forums.
The "Creative Audio Service" should be on by default after you install the drivers. To check open Services (click on the Start orb and type in services), and see if it is set to on and its startup is set to automatic. When it is running it will show up in Task Manager as "CTAudSvcService.exe".
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Hi!,
thanks for your answer but the problem is... in the Services (local) there is not Creative audio service, only ALchemy, audio licensing and media toolbox.
Windows seven
Mac Pro
8,00 GB
Apple Keyboard
May or may not help but have you tried this driver set yet?
SB X-Fi Series Support Pack 2.0 (05/15/2009) - Sound Blaster - Creative Labs
And yes i have that service (disabled as i don't have/use DDL).
P.S. Have you tried using those headphones connected via analogue? If not might want to give it a try. Set it to 5.1 in the Windows peaker settings, then set it to headphones in the X-Fi controls and enable CMSS3D,
X-Fi CMSS-3D Headphone - Guru3D.com Forums
and,
Guru3D.com Forums - View Single Post - CMSS-3D useless?
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I'will try this drivers and this another way with analoge.
Thank you so much bro!
Windows seven
Mac Pro
8,00 GB
Apple Keyboard
YEAH!, thanks dude, it runs NICE!!!!
Thanks!!!
Windows seven
Mac Pro
8,00 GB
Apple Keyboard
Good to hear (no pun intended). :)
P.S. Out of curiosity digital or analogue?
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Digital!, run nice!
Windows seven
Mac Pro
8,00 GB
Apple Keyboard
