Windows 7: Sound cuts out and stutters
24 Jun 2011   #1
Lee Dizzle
Windows 7 Home Premium
Hi Guys
I'm having a lot of problems with my sound at the moment, and I have no idea why it's happening, basically no matter what sound I listen to through my pc it stutters and cuts out then comes back on which as you can imagine is very annoying when listening to music or in the middle of a film! I thought maybe it was a heat problem so I moved the pc to a well ventilated place, but I'm still having the same problem! I've run virus scans and they all came back clean, so to be honest I'm baffled as well as annoyed by this problem.
Please help!
24 Jun 2011   #2
Devux
My first guess would be the driver for your sound card or motherboard sound output. Check in your device manager, see if you have the most up-to-date drivers, and if you do have the most up-to-date drivers from Microsoft, try getting the drivers directly from your sound card manufacturer.
25 Jun 2011   #3
fireberd
Generally, the Microsoft drivers are not the best or even the latest drivers. On some PC's, especially Dell's with the integrated (on the motherboard) audio, Dell sound drivers are needed as non-Dell will either not work or not work correctly.
Because of Microsoft's validation procedure for drivers and software, it can take a long time for a submitted (to Microsoft) driver to be validated and show up and in many cases the vendor has issued later drivers.
25 Jun 2011   #4
Lee Dizzle
Thanks guy's I will try and let you know if I have any joy
25 Jun 2011   #5
cruisecontrol
Windows 7 Ultimate x86
I've been facing a similar problem (see my thread for details) and I've just fixed it! Here are the steps I followed....
Downloaded Realtek HD Audio Codec from Realtek website
Downloaded the latest driver update for my sound card (compatible for my Win 7)
Reinstalled Win 7 from scratch
Installed Realtek Codec
Installed sound card driver
and voila! No problems so far. No lags, no freezes, no stutters. Audio playing smooth as butter.
My laptop sound stutters
Please help me people! I'm having a problem in my laptop, which is sound stuttering. It's really annoying! I get sound stuttering usually in games like WOW, COD4, Valve games and GTA VC/SA. The stuttering occurs whenever a sound plays, like in CS, when a guy talks "Fire in the Hole!". My game...
PC sound stutters
This may be a little OT, but I don't know where else to turn. I've tried several of the sound system forums but haven't gotten any help. I'm having trouble with the audio system on my computer. When I play a YouTube video or even just an audio CD, it will play fine for a while and then stutter...
Sound cuts out
I have this intermittent problem, where the sound cuts out for a fraction of a second (it's not muting it, it seems to lose the signal for a split second). It seems to happen when connected through SPDIF to my receiver (I haven't had it happen with Headphones connected). I am almost certain it is...
sound cuts out
Only real problem so far i have found with Windows 7 is that the sound cuts out at random times. Theres dead no sound and in windows media player the file will not even play. But in steam/msn/windows there is no sounds. I have to log of for it to come back.
Realtek ALC 889 Sound cuts
Hi there, I have motherboard gigabyte MA790GP-UD4H, which goes with Realtek ALC 889 A chipset. I have installed latest drivers from gigabyte and realtek (version 2.9 of codecs and AC97 codecs) Tests runs correctly with "Dolby Digital" and 44.1 khz and 48.0 khz. Tests also works with...
