Audio Stuck in a loop!!
  1. Posts : 25
    Hello, the problem is that sometimes the audio just gets stuck and i just formatted my computer and the reason i did it was because of the audio problem but it still hasn't done anything to fix it. This happens about 3+ times in about 4-5 hour period more depending on if im listening to music or something and sometimes if i don't have any audio on and i try to listen to something its just audio its like its stuck on a loop or being mute and other times like when im playing a game or something it'll keep playing that sound over and over and its SO DAMN ANNOYING!!! I have to keep restarting my computer like once an hour and thats irritating when your doing projects on after effects or doing anything actually.
    My speakers are The "Logitech LS 21" idk what the problem is!! its been happening for like 2-3 weeks. i thought it would slove it if i reformatted but nooooooooo!
  2. Posts : 25
    Yeah, but I meant that it wouldn't have much to do with your speakers specifically, it's an issue with your sound driver. Especially after noticing that you mentioned it's everything that involves sound. So that already eliminates application's themselves. Try reinstalling and make sure that your driver is up to date, since you did just do a format and start from scratch.
    I updated the driver ill see how it goes today, and ill get back at you.
  3. Posts : 25
    Updating the driver didn't fix the problem, i still have the issue. IDK what to do its really killing me..how are you suppose to do anything if this keeps happening.
  4. Posts : 25
    So i think the problem might be this program i use to make the audio sound better its called "SRS Audio Sandbox" lets see if it fixs the problem.
    Thanks for all your help guys!
  5. Posts : 25
    Guys i think the problem was the Program "SRS Audio Sandbox" oh well...i can live without it.
