Still no sound
I have reinstalled adobe flash player and there is
still no sound. When I watch a youtube video or anything else.
Only in itunes is there any sound.
OS: Windows 7 32-bit
How do I find out the system specs?
Download and run Speccy - System Information - Free Download , which will tell you all your specifications. You can either post a screen shot or however you want to transfer the information :)
Goto Control Panel, Hardware and Sound, Click on Sound, and tell us what you see there. Here is what mine looks like, see attachment.
Well, if you only see the speakers, then it should work. ITunes probably has its own volume control, did you check the volume control when you try to play other sounds?
