Windows 7: Sound volume goes down to 5% after connecting removable device
02 Jul 2011   #1
Windows 7 Professional x64 SP1
Bucharest, Romania
Hi
I recently noticed something very weird: every time I connect a removable device such as USB flash drive or external HDD or even my smartphone, the sound volume goes down to 5% but only for the browser & mediaplayer. I can change the sound volume using volume mixer but it's annoying doing so every time I connect something to my PC.
I reinstalled the drivers for my sound card & for every device I usually connect & also I reinstalled the browser(Opera browser) & Winamp without luck.
Also, I had some problems in the past that might be related to this one. After installing SP1 every time I logged into windows I was notified that Audio Service is not running although it was running. (solved this one).
Another problem was related to USB removable devices. Apparently Windows was unable to assign letters to all my removable devices, even if I manually assigned a letter to a certain device. I didn't solve this one, however I use USB Safely Remove to assign letters and it seams to be working fine so far. ( Windows 7 does not assign drive letters to external HDDs )
Any ideas?
07 Nov 2011   #2
Bucharest, Romania
Yeah, well it's a little bit too late but I solved this.
Control Panel -> Sounds -> Communications tab ->When Windows detects communications activity -> Reduce the volume of other sounds by 80% was checked
I switched to Do Nothing and so far it seams to be working.
Don't know exactly why hard drives were detected as communication devices but my guess is that this has something to do with Winamp/WMP library since I am always asked by these 2 apps to add the new device to Library, even if there's no audio/video/image file on it.
 Sound volume goes down to 5% after connecting removable device problems?
Similar help and support threads for: Sound volume goes down to 5% after connecting removable device
Changing portable device to removable storage Hardware & Devices
IDE Hard drive detected as Removable device Hardware & Devices
network card as removable device? Network & Sharing
hp 4515s problem-hdd and wireless as removable device Drivers
Where the removable disk volume label? General Discussion
