Windows 7: Need help: game, music, etc sounds going through microphone.
06 Jul 2011   #11
Windows 8.1 Pro RTM x64
Right-click the speaker icon and select Playback devices or Recording devices or Sounds (it doesn't matter which). Click on the Communications tab. What does yours show?
Need help: game, music, etc sounds going through microphone.-capture.png
Try setting the option to Mute all other sounds to see if that makes any difference. Don't forget to click OK to apply any changes.
06 Jul 2011   #12
Tried all 4 options and the problem still persists.
Its like my sound output goes directly into input, the other people on skype / ventrilo can hear perfectly what music i am playing in winamp / media player or any other application. I dont have any codecs installed.
Ive tried uninstalling the realtek drivers and removing all registry entries of realtek and using the default windows drivers, the problem still persists. Also re-installing the latest realtek drivers, problem still there.
06 Jul 2011   #13
Win7 Ultimate x64
Experiencing the same issue, would be nice to get some help.
07 Jul 2011   #14
Does it make any difference if you mute your speakers? What I am thinking is if you are still listening to your music and other sounds from your PC whilst trying to communicate on Ventrillo/Skype, then the microphone is picking up your voice (as it should), but also the audio output from your speakers.
07 Jul 2011   #15
The speakers are unplugged , they can still hear everything.
08 Feb 2012   #16
Windows 7 Home Premium 64-bit
I know this post is old, but I am having the same problem, and have tried everything the original poster did. Does anyone know of a solution? My Realtek HD driver is from 12/16/11. Thanks for any help.
(When I had this problem in previous versions of Windows, I could open my volume control, select my mic and check a Mute box below the slider, and it would stop sending out whatever I was listening to, and just broadcast my speaking. I cannot find where/if this is an option in Windows 7)
16 Jun 2012   #17
Windows 7 Pro 64 bit
Now I was having this problem, just then i accidentally opened the volume control options and discovered that 1 of the boxes that was ticked said "All devices currently playing sound" un-tick this it should work then.
Need help: game, music, etc sounds going through microphone.-volume-control-options.jpg Need help: game, music, etc sounds going through microphone.-volume-control-options-box.png
Search this Thread:
Advanced Search
Microphone picking up sounds, but not voice.
Hi all, I am trying to get my microphone (a Samsung earbud mic) to work. My computer can hear everything that is "loud", like when I tap the microphone on the desk or when I breathe heavily into the mic. But the mic can't hear my voice at all. The microphone boost is maxed out (at 30 dB) and the...
Stereo Mix-How To Record Microphone and Music
I have a Dell Inspiron 1545 and have been working on this stereo mix problem for a few hours today. Here's the solution I've found using Windows 7 and the IDT High Definition Audio. This should work for any Window 7 system having the seeming lack of a stereo mix capability. 1. Go to the...
sounds freezes when playing music for a couple of seconds
hello i notice this problem almost 1 week ago and cant do anything about.. when i play music in windows media player or traktor it freezzes for 2 sec and then back to normal.. its really annoying and dont know where to start looking for the problem.. i check windows logs in event viewer but didn't...
No sounds or music in games
Hi ! I have a problem. Exactly i dont have any sound in games and i cant play any MP3 file through any player. I've tried all players i know. BS.Player WMP Winamp VLC Please help someone, its boring to play games if i have no sound.
Music playback knocked out by other sounds
Hello, hope someone can help me! I've recently started using Windows 7, and am having an annoying sound issue. If I'm playing music or listening to an internet radio station either through Windows Media Player or through my internet browser, if I then get another sound come through in...
Music sounds like static
Hello all, I just installed win7 on my new system about 2 weeks ago. Everything should be up to date because I went through and updated everything after I installed. I finally got around to setting up my XBox as a Media Center Extender and when I went to listen to my music on my Media...
Media Center
