Windows 7: No Sound!!! PLEASE help!
06 Jul 2011   #1
briharper
Windows 7 Ultimate 32 bit
Ok, I think I have tried just about everything... Gateways website, Windows website, Realteks website, the E-recovery CD's (which didn't work!) uninstalling, re-installing, disabling, re-enabling... you name it! Here's the story:
back in Feb 2011, I had a virus, hired a guy to come fix my computer, which he did, he removed the virus, etc. the op sys that came preinstalled on my computer was Win 7 Home premium 64 bit, everything worked GREAT until the virus in Feb. He didn't have the right op sys to re-install, (and at the time, i didn't have the E-recovery CDs) So he installed Win 7 Ultimate 32 bit. since then, I have no sound, and no mic.
As I said, I've tried just about everything, that I've been recommended by each of the above mentioned websites. NOTHING has worked, and it's driving me nuts!
SO, if anyone has any new ideas, PLEASE let me know! I've even tried running msconfig and disabling the programs and services, thinking there might be a conflict, no luck so far.
OH! and one more thing, twice now in the last few weeks, I have heard A SOUND, but only for a min. The first time it played one sound, then quite working. The second time, just last weekend, I heard the same sound! So I opened up the personalization page to select the sound themes, and played a few test sounds, which worked!!! Then, unfortunately, my computer froze up (which happens more often lately, not sure why?) and by the time my computer rebooted, the sound no longer worked
Now I'm thinking it's just something that is causing a conflict, rather than the drivers, or broken hardware, since I was able to hear a few sounds!!! YAY!
So, how do I find out what is causing the conflict!?! AND, I would also like to restore the Win 7 home premium 64 bit, but apparently, the e-recovery disks don't detect the esata partition or something like that so I've been told!?!?
ANY HELP WOULD BE GREATLY APPRECIATED! email me at briharper@ymail.com please! THANKS SOOO MUCH!
06 Jul 2011   #2
LiquidSnak
W7 Professional x64
Do you have your product key handy?
EDIT: I don't want it, just wondering if you had it handy for a fresh install
06 Jul 2011   #3
briharper
yes, I have it, the sticker is on the bottom of my laptop!
06 Jul 2011   #4
LiquidSnak
W7 Professional x64
i am thinking a clean installation of windows might be the solution, or at the least, a repair install... You seem to have exhausted other resources from what you said in your first post
06 Jul 2011   #5
briharper
that would be fine, I have all my files (except a few recent ones) saved to an external harddrive... but the problem is, I don't know how to do that... and apparently the E-recovery discs won't work? i have asked someone else about it, and he has said he could take a look at it for me, but his dad recently died, so he's busy and I don't want to bother him.
but he did some research and said the CDs have some sort of problem and won't work?
06 Jul 2011   #6
LiquidSnak
W7 Professional x64
Since you have a product key, I would search for an ISO of W7 install DVD and burn it to DVD
06 Jul 2011   #7
briharper
any reason why it would have played A SOUND and then immediately quit working again?
06 Jul 2011   #8
LiquidSnak
W7 Professional x64
If it's not a driver problem or an OS problem, then it's a hardware problem. There could have been many reasons that you got a short bit of sound and then it quit again, most of which are un-fathomable to me
07 Jul 2011   #9
TVeblen
This seems obvious, but you never actually said so.....
Did you install the W7 32bit sound drivers for the NV59 from Gateway's website?
If yes, have you tried uninstalling the sound device from Device Manager, rebooting, then reinstalling the correct sound driver for your (32bit) OS?
If you post the full model number of the NV59 we can look at the drivers too.
08 Jul 2011   #10
LiquidSnak
W7 Professional x64
Good point!
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
