Windows 7: Computer crash, audio problem?
20 Jul 2011   #1
gexizzle
Windows 7 x64
Iv'e had this problem for about a year and a half or so now, maybe a year. My computer will randomly crash when I run certain programs or do certain things on my computer, most of the things are generally audio oriented. If I go to try and run Call of Duty Black Ops, or if I try to run X-Split Broadcaster, or load up Sony Vegas, my screen will look "staticy" if you get what I mean, and I will hear a weird buzzing noise in my headphones and I will generally get some type of multicolored screen along with the static. From there the computer will proceed to crash and restart.
When the computer is starting itself back up again, and once my programs are loading once I get back on my username, for a while it would come up with a windows thing about an error, and when you ran the diagnostic or whatever it was, it would say it was a blue screen error. If I went to look for the cause of the problem, it would say they couldn't find one or something like that, I can't remember exactly.
I wouldn't get this crash only with loading those programs though. If I mess with my recording settings within my audio panel, like my default recording device and things like that, I often times get the crash, or even if I just simply unplug my microphone, my computer can crash, or if I plug it back in if it didnt crash when I unplugged it. All of these crashes started happening when I started using the Rode Podcaster microphone. And back when I used the Samson CO3U I could even get this crash if I loaded up audacity and recorded something and tried to play it back to myself, It would sometimes crash then as well. Iv'e even had it crash while pressing disconnect on ventrilo. These two microphones are USB microphones. Note that these crashes would also just randomly occur back about a half a year ago, it dosnt really do that anymore, nor does it come up with an error message telling me about a blue screen error anymore once I start back up. It also, very rarely still happens when a LOT of things are going on on the computer at once. Sometimes if Im trying to load a lot of videos or just things in general at one time, I will experience this crash. Not ALL of the crashes have multicolored screens, none of them have had blue screens, but they almost always have a buzzing noise in the headphones.
Finally, I must say I'm getting quite tired of this. If I right click on Computer and go to manage then audio devices and all of that stuff, I see, High Definition Audio Device (AMD High Def audio device used to be there, but I deleted it because I thought there was a driver conflict). There is also the Rode Podcaster, and VIA High Definition Audio. Though I also think there are Realtek drivers on my computer as well.
If someone could help me with this, it would be much appreciated, thanks!
Also, one more note. Whenever it would crash when I loaded Sony Vegas, it would crash when it was loading the sound portion of it. And these crashes are sometimes hit or miss, because sometimes I can load up X-Split with no problems, but sometimes I can't. Same would go for when my audacity would crash, its just random sometimes.
20 Jul 2011   #2
Existence
Windows 7/Linux Mint
Ah, that's a typical audio hardware IRQ conflict.
First, click here to read more about this problem.
Follow these steps:
1. Reinstall the audio drivers. Simply go into Device manager, then select the audio drivers, then select update.
2. Grab the nearest broom, then try inserting it into your CD drive. Sometimes the drive gets dusty inside, and this'll cause the drive's IRQ to conflict with the mic, causing the exact problems you described.
3. Overheating can also cause IRQ conflicts - grab some ice cubes and lay them gently on your CPU.
4. This can also occur if one watches too much gay porn - make sure you don't watch gay porn.
If all else fails, buy a Mac, they're so much better than PCs anywayz.
01 Jan 2013   #3
42oL33t
Windows XP Home x32
same problem
I am having the same exact problem as the last guy. Whenever i attempt to do anything involving my Microphone, my computer Blue Screens, then quickly shuts off. and i believe it says pretty much exactly what it said for him as well.
When/if i attempt to record with windows recorder my computer crashes too. but it says something different, meaning nothing. at the botttom it says ***STOP-0000000x19c-000... or something like that. does that shed any light on the situation? Also i believe it might be a problem with my computer not having a big enough power supply. im running a 350 and i think i should buy a bigger one, but thats just me. if anyone can shed some light on the problem it'd be much appreciated. Thanks!
Realtek audio crash
I have a relatively new computer with Windows 7 Pro 64 bit installed, along with RealTek Audio. For some reason, I get a little red x over the speaker icon, which I then click, which brings up the wizard that fixes the issue, at least until it occurs again, which it does frequently, even though my...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Need expert for difficult computer problem - random crash/lockups
I've been building PCs for my personal use for almost 20 years, and my latest HTPC I built about 8 months ago. It's fairly basic, a Gigabyte motherboard with 8GB RAM (2 sticks), a Sandy Bridge i3, a BD drive, and a RAID card with 3 attached HDs in a case with an Antec Earthwatts 380W PSU. It ran...
Audio Crash in Windows 7
The problem I am having these days, is that suddenly, the sound breaks, stops working, and I have to reboot the pc. In previous versions, this was wrong, therefore, breaks and restarted the Windows Audio service, without having to reboot the PC. Now, yes or yes, I have to reboot. And it's a...
Graphics and Audio Crash!
Ok so Ive had a reoccuring issue for a while now where my computer completely freezes. (this includes video and audio) This happens when I am a. playing a game or b. streaming a video online I have never had an issue when watching a video from my hard drive. Originally I thought it was...
