Sound Crackling/ Fuzzy
Hi, I have just updated my Audio Driver, and now my sound is crackling/ fuzzy.
What shall i do?
What shall i do?
If it was the updated driver that is causing the problem, you can go to the Device Manager and in the Properties for your sound device you can click on the Driver tab and the select the option to "Rollback Driver" which will revert it back to the old driver.
Welcome to SevenForums.
First try the roll-back solution. If that doesn't work then:
Audio Video WMP problems
Fix it Center Online
Fix it Solution Center
Fix WMP video, other media, or librarry issues
Missing Playback_Recording (Disabled) Devices
No Sound in Windows
Open the Hardware and Devices Troubleshooter
Win 7 Problems Solutions Troubleshooting
Windows 7_ top solutions - Help & How-to - Microsoft Windows
WMP video, other media, library
