No sound after removing soundcard
Goldenben
7:14 AM
Hi all,
I removed my emu 0404 soundcard after problems (it's known to have problems with W7).
My sound (with onboard) was working before installing the Emu.
What have I done wrong?
http://i30.tinypic.com/10dsk7k.jpg
Windows 7AMD Phenom II X3 720 Black EditionOCZ Value OCZ2V8004GKSapphire HD 4650 512MB GDDR3 PCI-E
self assembled
GA-MA-790X-UD4
none
Samsung syncmaster 2693HM
Samsung Spinpoint F1 HD103UJ, 1TB
Antec Sonata III 500 Zwart
DN
did you remove it after or before the installation of windows 7
Windows 7 Build 7600 64bit/Ubuntu/Leopard4 GBNVidia Geforce 9600m GT
Acer Aspire 8730-6951
Have you Tried setting your speakers to the default playback device?
W7 RTM Ultimate x64Intel Q8400 @ 2.66GHZ4GB DDR2-800Gainward GTS 450 GLH 1GB Edition
W7 RTM Ultimate x64
Gigabyte GA-EG45M-UD2H
4GB DDR2-800
Integrated 8 Channel
AOC 23.6 Inch Widescreen LCD
Seagate 500GB Internal
Western Digital 1TB Internal
Hitachi 1TB External
Apevia Java Power 500W
Cooler Master HAF 922 Black
Stock Intel CPU Fan
1.5MB
First I installed windows 7 without soundcard.
My sound stuttert so I installed an Emu 0404
Then sound stopped with the Emu 0404
Then I removed the Emu.
I am sure it's a settings problem.
self assembled
GA-MA-790X-UD4
none
DN
was vista installed before or xp.
Set speakers to Default Playback Device?!?!
W7 RTM Ultimate x64
4GB DDR2-800
Stock Intel CPU Fan
1.5MB
self assembled
GA-MA-790X-UD4
none
DN
Hi Goldenben, welcome to the forums.
The best thing to do IMO is to uninstall all sound devices in 'Device Manager' then scan for hardware changes. This will force Windows to re-configure and if need be, download from Windows Update and install the sound card. This will also set all defaults to the newly installed (old :p) sound device.
Hope this helps :)
Windows 7 Ultimate x64AMD Sempron Dual Core3GBNVIDIA GeForce 6150SE nForce 430
Compaq Desktop
3GB
1024x768
150GB Sata
And we have lift off...
Thanx Shark. That did the trick.
self assembled
GA-MA-790X-UD4
none
DN
Compaq Desktop
3GB
1024x768
150GB Sata
Getting EMU 0404 to work.
@goldenBen,
Hi, glad to see your problem has been fixed.
But your EMU 0404 is far superior to the onboard soundcard.
If you are still interested in getting the EMU to work, I think I can help you.
I have the EMU 1820M. It has more in and outputs, but the engine is the same.
If by tomorrow you haven't read this post, I will PM you.
Greetz
Win7 Build 7600 x86Pentium II 300MHz32mb EDO RAMDiamond Viper
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
14" AOC CRT 16K color
800x600
300mb Quantum fireball
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
Just a tip for future reference, the prob most likely resulted by simply removing soundcard and leaving drivers behind (ye all wonderful in hindsight). As a future tip, before removing core hardware, use Device Manager to "uninstall" the drivers... this removes any incompatibility issues, and in this case, would have allowed system to revert to embedded sound card.
By the way, given the attitude of EMU in the quoted response below someone else got from them in regards to the issues with Win7, I might recommend looking elsewhere for a sound-card.
Dear Valued E-MU Customer;
We are sorry to inform you that we have no information or support for Windows 7 and E-MU products at this time. Technical Support is not the place where future, new features or product development is discussed.
Nor is it the place where we discuss or disclose upcoming product development or non released features and functions. That is done via marketing, usually through an official press release, and usually done at a trade show event and/or posted on our website.
don't you just love it?
Win7 x64 & Vista Ultimate x86Intel Core Duo T7500 2.20 GHz2GB (meaning to upgrade to 4GB)GeForce 8600M GT
ASUS G2S
GeForce 8600M GT
Realtek High Definition Audio (exact model unknown)
in-build notebook (second BENQ 19" in storage)
300GB internal, dual partitioned
500GB external WD
diNovo Media Desktop Laser (BlueTooth - love it)
as above
1.5Mb
Speakers - Altec Lansing FX6021... blows away most 5.1 speakers on the market
It was almost definitely the E-MU drivers that silenced your onboard audio. Thank you kaninelupus for posting that letter from E-MU, I will not be shopping with them again!
Windows XP x64Intel Core 2 Quad Q9450 2.67 GHz8GB DDR2NVIDIA GeForce 8800 GT
HP m9200t
Windows XP x64
Asus IPIBL-LB
8GB DDR2
Integrated Audio
Agreed, their service sucks big time!
They are also in the habbit of dropping support for your hardware quite quickly, so you will buy new stuff.
But, yes there is a but.:D The soundcard I have is a 1820M and the quality of the components in this card are up there with the studio grade soundcards costing between 2000 and 4000 euros. (the main chip is even identical to a 3000 euro motu card)
This card however has cost me 399 euros, way under the price to manufacture the thing.
(it was an attempt of EMU to get into the highend market, but it was a big mistake because no Pro studio would buy it because at 399 euros, how good can it be? Plus they didn't trust EMU to support it long term, and rightly so.
For home users 399 was still a heck of a lot of money for a soundcard, so they soon took it out of production.)
The price I have to pay for owning a pro grade card is the lousy service they provide and the absence of long term support for it.
Luckily the Vista 32 and 64 drivers work flawlessly under Windows 7!! Yay!! :D
Win7 Build 7600 x86
Pentium II 300MHz
Asus
32mb EDO RAM
Diamond Viper
Soundblaster 16
800x600
110 Watts
Passive
Trust Ergonomic
Generic
256K u 128K d
Me too, I try to use E-Mu 18020m with Win 7 Pro x64. I does not work; Windows Media Player does not play anything. Your held would be appreciated :-)
Windows 7 Professional x64
Ditto
I am also having trouble getting my EMU 1820m to work. I tried the Vista drivers, then switched to the june 2010 beta driver from creative labs for windows 7. Nothing works.
I am desparate here. I am unable to record vocals for any of my new songs and technologically impaired.
ANY help is very much appreciated.
Windows 7 Home Premium x 64Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz4.00 GB RAMIntel(R) G41 Express Chipset
Dell Inspiron 537s
4.00 GB RAM
E-Mu 1820m
1150 GB
In my case, setting the sound to 24 bit via the Windows 7 Control Panel solved the problem.
