Windows 7: Notebook connected to TV with HDMI cable doesn't work. Help pls!!~?
02 Aug 2011   #1
Windows 7 Home Premium 32bit
I have a notebook..
Model : TOSHIBA Satellite L-510
and a TV
Model : SHARP LC32A37M (http://vlv.am/wp-content/uploads/pro...9192168124.jpg)
I have a HDMI cable and connected them both.. There are PICTURES.. but no sounds..
Please help.. Maybe if you think I need to install something additional please give me the sites.. Thanks...
My mom has been trying to fix this since last week..
02 Aug 2011   #2
XP Professional, 7 Professional
Have you checked the default audio device settings in your sound control panel?
02 Aug 2011   #3
yeah.. under the control panel : sounds..
i checked.. its default on HDMI something something but no sound from tv.. when i play a music.. i see the METER going up n down means there is suppose to be sound but my laptop n tv no sound..
02 Aug 2011   #4
My buddy used to have this problem with his laptop and TV. I can't remember exactly how he fixed it, but it had something to do with a second or third tier setting within the audio device preferences. Of course, that was an XP operating system, and the hardware was older. It was exactly as you describe though, including the sound meter registering a signal, but no sound from the speakers.
I'll try and get in touch with him and see if he remembers the fix he used. But if I were you, I would search the web for the exact model and issue you're facing. Also, you might check all the audio settings on your T.V. as well. Sometimes if you dig deep enough into the internal menus you can find a setting that's incorrect.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
